Results 1 to 15 of 15
    Veteran Member Three Rings tehbry's Avatar
    Aug 12 2012
    Atlanta
    I thought I had a pretty good grasp on ATF
    So I've read the ATF change for the B6 A4 quite a few times and I thought I had a pretty good grasp on it. You refill the trans while reading 32-34 C through vag and when it will no longer except more fluid while at that temperature range its full. So today I wanted to add 6oz of Auto RX to my trans to do some cleaning before I do my next ATF change. I went out and raised the car on ramps and stands and let the car cool for 2-3 hours because It was cranked and ran for a few minutes. I pull out the fill plug on the trans and fluid starts POURING out. I left the car alone for 2 more hours and tried again, same thing. At this point I decided to bust vagcom out and check the fluid temperature and it was only reading 23 C.
    I was thinking that if the fluid temp was nowhere near 32-34 then NO FLUID would pour out of the fill plug. I'm guessing this means the shop that installed my torque converter added too much fluid?
    B7 A4 2.0tQ tip - Motoza stg 2 93oct - JHM FMIC/HPFP/T-pipe - HPA K04 - BBoat downpipe/exhaust - 034 motor/trans/snub mount - GFB DV+ - S4 Calipers/EBC pads/SS lines - Avant Garde M540 19x9.5
    Jan 09 2012
    MA
    Don't take this as gospel as I have a real transmission on mine but normally auto's are checked while the engine is running. At least my wife's BMW is.
    Aug 12 2012
    Atlanta
    lol you have a real trans huh? You must be real proud of yourself
    Aug 12 2012
    Atlanta
    Though I admit you may have a point in that I did not have the car running
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Hey just so you know for next time when the trans is hot the fluid level will be at it's lowest. In not sure for the exact reason, but this is why they tell you to check at 32 because you can never get the correct amount of fluid in when it's cold.
    Sent from my LGL33L using Tapatalk
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Aug 12 2012
    Atlanta
    Oh
    Aug 12 2012
    Atlanta
    Grr I hate not being able to edit on my phone. I meant to say: oh ok, so if I were to remove the fill plug after my 20 minute drive home there will be less fluid in the pan so none should spill out while I'm trying to add the Auto RX? See I was thinking if I removed the fill plug with the fluid pretty much as cold as possible would mean with the fluid thick it wouldn't drain out. So if I need to add the Auto RX with the fluid hot, should I do it with the car running?
    Jan 06 2009
    You need to remove the FILL plug with the engine on (ie trans pump circulating). If you remove it with the engine off (trans fluid not circulating) then the level in the pan will exceed the fill line and leak out. Also, when you do your flush and start adding new fluid, once you get it full (fluid begins to drop out the fill port with the engine on) make sure you install the fill plugBEFORE you turn the engine off. If you turn the engine off before re-installing the fill plug a ton of your new fluid will gush out.
    I hope you added more fluid or have not driven since accidentally draining fluid out....
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Jan 06 2009
    This is all covered in the factory fluid flush procedure so I suggest you read that before attempting again as there is more to it then just draining and re-filling...
    You need to fill the fluid, cycle through gears, fill fluid, cycle through gears, etc.
    Oh and ONLY use Audi fluid or ZF lifeguard fluid. Unless you want to do a trans swap in the near future.
    B7 2.0t
    Aug 12 2012
    Atlanta
    Ok so do it with the engine hot and running. I only drained about 1/16th of a quart so I'm not concerned with the ride to work and back, the car drive fine. I collected the fluid and will re-add with the Auto RX.
    Aug 12 2012
    Atlanta
    Wait actually im not sure if I should do it while below or above 34 C while running. Wouldn't removing the fill plug with the temp past 34 C cause the fluid to drain out the full plug?
    Aug 21 2009
    NO
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Quote Originally Posted by tehbry View Post
    http://www.audizine.com/forum/showth...TF-Replacement works with B6 too....
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Aug 12 2012
    Atlanta
    Thanks, going to use that for a fluid change after I run the Auto RX for awhile. I noticed one of my trans pans bolts are stripped so not sure what I'm going to do about that but I'll figure something out. I believe they sell special sockets to remove stripped bolts.
    Feb 27 2011
    Winnipeg
    Cut a slit in it and use a flat screw driver or a hammer and chisel to remove it
