Those of you that are running a downpipe, how are you guys dealing with emissions testing?
I had looked at the CEL-free high flow cat/downpipe setups, but most don't have the OEM mounting bracket on the turbo side with Milltek being the only exception.
I've also heard that some downpipes with the magna flow cat at the stock location have been able to avoid a CEL even without a spacer.
However, it seems that most also don't have the OEM mounting bracket except for the unitronic one.
The downpipes with the Cat in the bottom section will most likely flow better since no cat immediately behind the turbo and it should put less weight on the turbo. But this setup will most likely throw a CEL when going to emissions. The ones with the stock location for the Cat don't have OEM support brackets and just hang off the turbo except for unitronic.
Interested to hear experiences from those of you that have installed a downpipe and if you were able to avoid the CEL without software.
-cW
