There is a definite delay in meth starting spraying in any usable gear (2nd or 3rd) where it starts spraying when you're well into your top TQ/RPM numbers (thus already spooled up) and if you set it to start spraying too early, you will flood and bog down the engine.
This is the reality with 99% of meth systems installed in wanna be race cars, e.g. cheap systems triggered by boost level (sic!) or maf/IDC (better).
To accomplish what you're talking about, you'd need super-expensive constant pressure solenoid style of meth system that can squirt very precise amounts of meth, at any IDC, at same pressure and atomization level (1000psi systems and such). This just doesn't happen in sub 1k systems.
As a result of using soemthing like devil's own or snow, you have a meth injection system that delivers fairly constant (regardless of its duty-cycle value) amount of meth regardless of what is the trigger value at any moment. Thus you end up with the amount of meth that usually is dialed for mid-high RPMs (Whcih is fine since system needs time to build up pressure and flow, you're past this area in low gears before it starts really flowing) and below that it floods engine (if you were to accelerate in 5th or so), above it is simply insufficient to keep EGTs in check...
In addition to the above, you'd be spraying the meth all the time you'd even touch the gas pedal so it would be a pretty expensive proposition. You'd probably need a second gas tank hooked up under the tank just for meth!
