Results 1 to 16 of 16
    Mar 01 2006
    Kitchener, ON
    rear inner tail light - LED replacement?
    Curious was looking at it, and figure it's all one piece? I can't replace the LED's?
    I noticed two were out.
    Can't seem to find a lot of information on it, but it appears you have to buy the whole unit?
    http://genuineaudiparts.com/parts/20...&siteid=214407
    It's not a huge deal, I think it's covered under warranty but I have a deductible so if I can do it for $50 then I would just do it myself, just curious if I should be wasting anymore time on it
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    If your under warranty why waste your time? Rockauto.com has good prices on these as well.
    Oct 31 2013
    Morris County, NJ
    LEDs rarely fail. I had a few intermittently go out on my mdx, unplugged the harness from the light and sprayed some deoxit into the plug. Fixed it and never happened again. Might be worth a shot.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by o1turbo30v View Post
    I just wanted to see if there was a quick fix for it. I have a third party warranty so they will still get me with a deductible, so don't want to jump on replacing it all right away. Likely wait till something else breaks lol, seems to be the story of the car last few months...
    I'll try the contact cleaner idea tonight on my way home, it's $6 fix attempt.
    Past
    Nov 30 2010
    Anchorage, AK
    I'm with you OP - I have two out on my right taillight and one out on the left. Irks me something fierce.
    I need to try the deoxit mmm def mentioned, because as he said LED's rarely fail, so I was surprised to see it.
    2010 Meteor Gray Prestige //S4 DSG
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    5 led's out on one inner tail light here, replacement is getting fitted this weekend. I don't think they are replaceable individually.
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by mmm def View Post
    ding this worked! sorta...
    Got a can of electronic contact cleaner ($5.00), sprayed it and one of two LED's came back...looking for one more!!
    So I totally understand the concept from highschool electronics class and playing with LED's etc. They last forever and are more energy efficient yada yada. HOWEVER, if there isn't enough power *correct me if I m wrong* then the LED won't light. By cleaning the contacts, you get more power, which causes LED's to light up.
    I got a can of compressed air from cleaning out laptops and desktops, give that a spray in the morning when I got more time and try the contact cleaner again. Hopefully all LED's will be alive again
    Hopefully this will help others in the future! Give it a shot anyway, best $5 (cdn so that's like $1 rest of the world) you might spend
    Past
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    Had this happen to my rear passenger taillight...3-4 LED's burnt out, brought it in and was replaced under warranty. There is actually a TSB for the replacement of the rubber seals behind the taillights which is letting moisture in behind them and causing the LEDs to fail. Can't remember the TSB number off the top of my head...
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Oct 03 2011
    2007 S46MT, 2011 S46MT,2009 R1
    Sacramento
    not to side track, but anyone got a good option for LED reverse lights?
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by dizzlesizzle View Post
    this actually makes total sense of why it would corrode over time
    I notice there isn't much sealing, DEFINITELY not air tight like on previous cars I ve owned
    Past
    Mar 01 2006
    Kitchener, ON
    just updating the thread to avoid someone going down the path...the 2nd LED went out again, then it rained and came back...this morning it went out. Tried cleaning and now it flickered, then went out again.
    Said screw it...off to Ebay, thank you Latvia...saves me $200+ for genuine OEM part
    http://www.ebay.com/itm/191442782989...%3AMEBIDX%3AIT
    Past
    Senior Member Three Rings Ciscokidz's Avatar
    Jul 07 2011
    2005 M3 Cabrio,1967 F100 Stepside 4X4, 1969 Lincoln Mk III 460, 1953 MGTD, Buell Lightning 900
    Northern VA
    Reviving this thread. My 2010 was just in for its 75K service when i noticed BOTH rear inner (trunk lid mounted) LED arrays were burned out. I had looked up this issue and can see many people have had this happen and the dealer service manager said it is common. It's nearly $700 to have them both replaced, and since I've noticed a LOT of A4s and S4's with this issue driving around. I hear rumours of a TSB but my service manager says there isn't one. Kinda wondering who else has had this issue?
    '14 D4 A8L 4.0T Earl Grey APR Tune
    '10 Prestige Brilliant Black ADS Sport Diff
    AWE Exhaust/downpipes/intake, ADV.10.1, APR Stage II+Pulley, RS5 Steering, RS6 shift, OEM Black grill, Fogs, LEDs, VCDS,
    "And in the decades following the second Great world War, there shall emerge an evil such as the world has never seen, he shall target those who worship the Four Wheels. He will inhabit the land of Europa and be known by a name: Bernie Ecclestone" --Nostradamus
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    Quote Originally Posted by RudyH View Post
    You bought an aftermarket set.
    - - - Updated - - -
    Quote Originally Posted by Ciscokidz View Post
    Just buy the lights off eBay but make sure you get OEM.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    One DIY:
    http://www.audizine.com/forum/showth...D-remplacement
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by Pared View Post
    - - - Updated - - -
    Actually, be careful with this.
    I started having some odd signalling issues with the replacement off Ebay. Like I would signal right, and it would blink once right, 2-5 times left then continue blinking right!!!
    I ended up just going to the car recyclers and grabbing one for dirt cheap, but it didn't quite fix the problem. Still happening, so Audi is thinking it is actually the entire turn signal assembly, that is covered under warranty and will get it done on my next oil change or service
    Past
