Results 1 to 17 of 17
    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Carlsbad, CA
    Engine Trouble - have you had this happen?
    Hi gang,
    While driving home tonight my allroad started to run very rough, the check engine light began to flash, white exhaust in copious amounts came out the pipes and the engine wouldn't rev over 4k rpm. I was only a mile from home so managed to get it into my garage.
    There is a very strong gas odor around the car. I checked fault codes via APR dongle and got:
    • P0087 Fuel Rail/system pressure - too low
    • P0300 Random/Multiple Cylinder Misfire Detected
    • P0303 Cylinder 3 Misfire detected
    • P130A Hide Cylinder
    • P2261 Turbo Boost Pressure Not Detected
    I called Achtuning to get their thoughts. Two suggestions as to what was going on:
    1. Coil pack failure
    2. Injector stuck open
    I swapped out the coil packs and started the car. Difficult to start, same symptoms.
    I should also say that I recently had the dealer replace the PCV as part of the recall.
    So, could this be an injector stuck open? It seems like it could be considering the extremely strong fuel odor.
    I will be towing the car to Audi in the morning. Thought I'd check with the forum.
    '19RS5 Coupe: Prestige, Daytona Grey, Blk Interior, Carbon Pkg, Driver Pkgs, APR+/TCU/Intake, CETE AVC, ABT Coils, Vossen EVO-1R 20x10et20
    '22RS6: Glacier White, Blk/Gray Interior, Blk Optics, Exec, Driver Pkgs, Sport Exhaust, APR+, Akrapovič Exhaust, CETE AVC/ASC, Vossen GNS-1 22x10.5 et7, Stealth wrapped Piano Black Interior
    Oct 10 2012
    Zionsville and Saint John IN
    Injector. Very common and under warranty until like 120k miles lol
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Aug 21 2010
    Carlsbad, CA
    OK, did a quick search and found this post: http://www.audizine.com/forum/showth...ms-Audi-A5-2-0
    Pretty much is identical to what I experienced. In that case its an injector stuck open.
    Aug 21 2010
    Carlsbad, CA
    Quote Originally Posted by richardm0025 View Post
    I think that you are right. I'll be taking to Audi in the morning.
    Oct 10 2012
    Yup. Not to bad of a fix either. Should have it back sooner than later.
    Aug 21 2010
    Carlsbad, CA
    That is good to hear. My biggest issue now is how to get the car towed there. Any Seattle area members have a recommendation for a flat bed tow service?
    Oct 10 2012
    When I had my car break down I just rented a flat trailer from uhaul along with boards and pulled it home 120 miles with the jeep. It cost like 50$ lol. Maybe call your insurance and see if they can get you a flat bed on them. Usually you get one free tow?
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    Not sure if you're in warranty or not, but on a 2013, wouldn't you have roadside assistance from Audi? If not, when I had an issue with my last A4 last year, I called up CAA (AAA in the US). Joined for $50 for the year and they sent a flat-bed. They new without even asking to send a flatbed. Only issue is that it will take a little while longer to get to you since they have fewer flatbeds on the road.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Aug 21 2010
    Carlsbad, CA
    I ended up using my insurance. Won't cover total cost of the tow but at least some of it.
    The car is out of warranty now. But I did buy an extended warranty when I got the car that will cover another $75 of the towing costs.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by pwdrskr View Post
    Should have asked around if anyone had AAA. They have free towing.
    My 2009 A4 Prem+ Build thread
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Make sure you get an oil and filter change...the leaking injector can dump a lot of fuel...which ends up in the oil pan.
    Aug 21 2010
    Carlsbad, CA
    Quote Originally Posted by S4'ed View Post
    Ah, good reminder!
    I'm also going to get intake valve carbon cleaning done (at the recommendation of Achtuning and service Audi advisor) since they will be in there anyway.
    Interesting side note related to the extended warranty offered by Audi from Fidelity. Talking with the Audi service advisor last night, he told me that Audi won't notify Fidelity that the car is modified (TD1) therefore there shouldn't be any issues with any repairs done (my car is over 50k miles). They basically just call up Fidelity and describe the necessary repairs and that is it. Interested to see if that bears out...
    Aug 21 2010
    Carlsbad, CA
    As suggested, cylinder 3 injector was bad. Will be getting the car back tomorrow afternoon. Decided to get valve carbon cleaning, replace the plugs and oil / filter change.
    At this point the remaining bummer is Crystal Mt ski area is opening my favorite chair tomorrow and I'll miss it. Loaner they gave me, an S4, has summer tires...
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    How was the condition of the intake valves at your mileage????. Curious
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Jun 23 2013
    PacNW
    Time to bum a ride to the mountain!
    Can't believe they gave you a car with summer tires when the sea level temps are in the 30s/40s.
    Deactivated Two Rings
    Oct 29 2015
    Bay Area CA
    They gave you an S4, wut.
    Aug 21 2010
    Carlsbad, CA
    Quote Originally Posted by hyperunion View Post
    I'll ask when I pick up the car later today.
    Quote Originally Posted by skis4hire View Post
    Quote Originally Posted by Haci View Post
    Yeah kinda lame that any car sold in the PNW wouldn't at a minimum have all seasons.
    On the other hand the S4 is quite a nice ride engine wise. Such an improvement over th 2.0t even after all the upgrades I've done. The supercharged V6 is NICE. Got me thinking about a new car. The allroad is paid off and with all that I've done I want to hang on to it. IMO it is the best blend between performance, driveability and function available in the U.S. right now. That said, I've been wanting an S5 for a while now and driving the S4 got me thinking of adding to the stable.
