Results 1 to 16 of 16
    Apr 15 2014
    Ottawa/Gatineau Canada
    At what point does the AMB 1.8t low oil light come on?
    I have been negligent and not checked my oil in a WHILE.
    Checked it today and it was LOW, past the hash marks and at the bend in the dipstick LOW :(
    Approx 6500KM (4038.913M) since last oil change. I guess my 2nd question is if this is normal consumption for this mileage. 270000KM ( 167770.222M ) on engine and had to put in approx 1/2L
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Senior Member Three Rings nross33's Avatar
    Jun 10 2014
    Orange County, California
    Yes, these engines guzzle oil like there is no tomorrow!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    According to Audi "normal" consumption as much as 1 litre per 1000 miles is within manufacturing tolerances. Sounds excessive to me.
    For what it's worth I have never had to add any oil between my 5,000 mile OCI's and I am now well over 200k miles. Initial break in is key. Unfortunately if you didn't purchase the vehicle new (as I did) you are at the mercy of the previous owner.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Quote Originally Posted by nross33 View Post
    Guess I'm just lucky? I never need to top up between changes, but do changes regularly. 145K miles. Do you remember checking it at all after your last change? If you're using a large filter the media can absorb a lot if you don't recheck after the engine is run for a bit. Much oil in your intercooler hosing or belly pan or the like?
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    I don't add any oil between changes normally. Recently I've been battling an oil leak from my FrankenTurbo F21L mixed flow. It will all(entire short block & turbo assembly) be coming out this week. Even with the leak I only add 1/2 quart every 3000m. The 1.8T as opposed to the 2.0T is a very tight motor and does not burn/lose oil if everything is in spec and there are no leaks.
    Sent from my LGL33L using Tapatalk
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Apr 15 2014
    How is this excessive? I have burnt thru approx 1/2L in 4000 Miles. By your listed Audi standards I should have gone thru 4L
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    I'm at similar mileage and just did an oil change and didn't add any oil since the previous owner changed it ~8000 kms ago. I know my half moon seal is seeping a bit, so I will need to address that before too long. Also, got my Blackstone labs report back with good comments.
    0.5L is probably not too bad, but definitely keep an eye on it. I check mine everyone ~1000 kms or whenever I have the hood up for whatever reason.
    Aug 13 2015
    NS
    Quote Originally Posted by Luxus Panzer View Post
    I think he means that the Audi standard is too excessive. Your consumption is not too bad, but check around the bay for some seepage somewhere.
    Dec 05 2007
    Only oil I ever lost was from leaks, and not consumption by a fault in the engine or turbo. Things running normal, I lose no oil.
    My main loss is at my drain plug. My best remedy so far was to take off the stock washer and swap in my own 14mm copper ones every OCI. Doesn't work perfect, but giant steps ahead how it was previous.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by eljay View Post
    Yep. I was referring to the Audi standard.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    In my 3.0, the oil light comes on when it is ~1L low. I would imagine that the 1.8T is similar, but it sounds like you were right at the edge of the light coming on.
    Apr 15 2014
    Seen
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Interesting. My 02 1.8 and my 05 1.8 do not lose any oil. I change the oil every 4000 miles and never have to add any in between. Both engines have 100,000 miles.
    Senior Member Three Rings GTA's Avatar
    Feb 08 2013
    2003 Audi A4 1.8TQ, 5-Spd
    Toronto, Ontario
    Luckily my AMB doesn't go through any oil at all between changes so the initial owner did break the engine in properly as OG mentioned. That's one of the reasons I'm keeping the car for a while. I currently have 225K km (140K miles) with a stage 1 flash and it pulls strong, though I can do without the initial turbo lag for city driving.
    Aug 27 2013
    Philly
    My 3.0 showed me the oil light once. Even when I pulled over when I stopped at a nearby Walmart for some Rotella, there was no oil on the stick. That was immediately after driving it off, so there could have been some oil that hadnt made its way back down to the pan yet. Either way, I was about a quart and half short (3.0 takes about 7 qts total). My oil leak was from the oil cooler housing. Pulled the "gasket" out (not the same as the 1.8) and applied some black RTV and its been good ever since. I burn probably a quart over 5k with 135K on the engine. I got it with 99k and a friend owned it from 88-99 so the first 88k is unknown to me.
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    I am going through the same thing. My only source of an oil leak is my drain plug, I've put in a new drain washer every oil change and have completely tightened it and still leaks oil through there slowly. The threads are probably messed up.
    Brilliant Red B6 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Grey B6 A4 1.8T quattro
    Brilliant Red B7 A4 2.0T quattro
