Machined aluminum lower spring perch for rear coilover set-up
Machined aluminum spring perches to replace the OEM lower bushing when using uprated springs (Hypercoil/ Eibach/ Swift/ etc.) in the rear of a KW or ST coil over set-up.
The plates center the spring and provide a secure perch for the spring to rest in. These perches are designed for use in the lower control arm and can only be used on a rear suspension set-up with a top mounted adjuster.
The perch is machined for a 2.5" ID spring.
List Date: 12/10/2015
For more info, click here to view the original listing: Machined aluminum lower spring perch for rear coilover set-up
This item is no longer available.
