Results 1 to 13 of 13
Thread: Rear sway bar
    Sep 05 2014
    Ottawa, Ontario
    Rear sway bar
    Getting conflicting information.
    I want to go to a bigger rear sway bar in my B6 Avant (sport suspension) and thought the B7 RS4 rear bar would be good. Is it a direct swap? Need new links?
    Cheers.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Good upgrade. Direct swap. Bushings and clamps are different from your stock bar. End links are the same (if old they should be replaced). It's what I'm running on my avant.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Sep 05 2014
    Ottawa, Ontario
    Great. Thank you so much for that quick clarification. Searching vendors confused me too with the different part numbers for a B6 S4 and B7 S4 (compare fitment shapes).
    I'll be ordering one up then. Thank you again!
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    I think the rs 4 swaybar is probably the best mod interms of ease of installation, cost and noticable benefit. The difference is quite noticible.
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Get the 034 rear sway bar!
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Veteran Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    swfl
    Quote Originally Posted by 19jdog View Post
    X2 the rs4 sway bar makes a big difference but without the 4:1 center diff mod leaves something to be desired as the understeer is still there. The 034 sway bar is solid construction as opposed to the rs4's hollow construction. The 034 bar is also adjustable. I had the rs4 bar and have now upgraded to the 034 bar.
    2.7 swap in progress
    Aug 30 2013
    Rockville, MD
    034 is really good, comes with bushings...something i didnt realize until i installed the bar and couldn't figure out why stock bushing wouldnt fit....
    Sep 05 2014
    Ottawa, Ontario
    Thanks for the input. The Avant is my daily driver and I really enjoy how smooth it is. I'm just looking for an upgrade, not a race car. ;)
    I'd like to keep the independent suspension working. Audi designed the suspension to do it's job very well and don't really want to mess with it too much.
    I had added a rear bar to my 85 GLH a few years back and it was beautiful. I am hoping, from what you guys attest to, that the effect will be the same. The less weight of the hollow bar is better too as the car is quite the pig already.
    Thanks again folks!
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    B7 RS4 bars are a huge upgrade over the factory non-sports!
    2019 SQ5 Prestige
    Veteran Member Three Rings maurizio's Avatar
    Sep 23 2005
    '09 Pilot
    Lake county, IL
    +1 for 034's RSB
    "Are you actually asking that question.. Just don't even post on my thread. why do I need to lie on an Audi forum about me fucking two bitches at once. (not literally) yes i did, you are late to the party.
    and this thread has ran out of gas. I just wanted to tell people about my experience I had 2 nights ago and felt like sharing it with my fellow B6'ers. And I thank the people who didn't hate."
    Apr 07 2011
    +1 for 034 but anything at this point would be an upgrade.
    Jun 27 2011
    This.
    I love my 034 bar and given the price relative to the RS4 bar I would go 034 all day every day. Plus it comes with urethane bushings and billet brackets rather than the squishy oem rubber ones.
    Also, top tip, B7 S4s came with the same 22mm bar as the RS4. Only the b6 s4s came with the 20mm bar.
    And for those complaining about the weight, swaybars sit 10" off the ground, pretty sure an extra lb or two that low down will make zero difference in handling. But the extra stiffness will definitely make a noticeable difference.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    The 034 is the way to go, on my stock sedan it feels like normal till you enter a turn then it feels so much more planted.
    I can't imagine the size a rear sway bar would have to be to make an independent rear suspension feel like a live rear axle or the like
