Fog lights can stay in. The harness is disconnected by the drivers headlight along with the light washer hose. But you will have to at least remove the fog grilles to get access to the bumper bolts. Small tip for further reference: if you ever move onto placing the front core support into the "service position" that requires you to remove the bumper shock absorbers. Most people use one of those three bolts per side to screw into the frame to keep the support from falling off. If you use the bumper bolts instead of the shock bolts, you will get an extra two inches of clearance between the support and the front of the motor. This becomes especially handy during timing belt jobs.
Also the hoses can be a pain if they haven't been off in a while. Pull out the retaining clip (you don't have to remove it, it will lock out after about an inch) and then start yanking on it. Be sure to check the o-rings are still in place also. If they haven't been replaced recently, I would recommend replacement but it's rarely necessary. When replacing, clip the retaining clip closed on the hose and push. As it slides into place, you will see/feel the clip expand and then lock back down when it's in place.
Putting the bumper back on can feel like a balancing act at times but is not impossible. Just go slow and make sure the bumper lines up to the sock supports.
Also, seeing as how you're already there and you have a high mileage car, I would consider a t-stat and J-plug swap. Both are pretty known to go bad. Finally make sure you get your G12 coolant from a VW dealer if you can't find it cheaper online. Some Audi dealers mark the exact same bottle up 100% ($50 vs $23)
Oh and make sure you use distilled or purified water when you mix it.
