Results 1 to 40 of 40
    Senior Member Three Rings astonmartin007's Avatar
    Apr 19 2015
    Plastidip- Wheels
    Guys ,
    I'm on my winter set for about 2 weeks now and simply hate the look
    So I was thinking to plastidip my winter set Black with Gloss finish.
    Thoughts?
    I can't powder coat them since my car is a lease...
    Apr 19 2015
    Here's pictures with summer/winter set
    Sep 16 2006
    SOLD: RS5
    I prefer your winter wheels so much more than your summer ones.
    __
    SOLD: []RS 5
    Suzuka Grey Pearl
    HRE|Bilstein|AccuAir|Capristo
    Nov 10 2014
    Apex, NC
    I prefer your summer wheels so much more than your winter ones.
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by astonmartin007 View Post
    Guys ,
    Thoughts?
    I say go for it.. if you don't like em.. you can always peel it off or do one and see if you like it.. the can's are cheap enough.. personally i prefer the satin finish
    Present:
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by ExhaustNote View Post
    this +235093258032623462347437437
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    I agree with the above. Keep them as is.
    If you must plasti-dip them I recommend matte black and then a metalizer rather than gloss. Gives a nice metallic flake to the black.
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Plastidip or Flexidip works well, and it's lasting nicely on my car. We had it through 3 winters on the Evo before it started to look like crap.
    It's a nice, cheap alternative if you're not looking to powdercoat them.
    This is 5 or 6 coats of Matte black with 4 coats of Glossifier. I used Flexidip this time around instead of Plastidip, and I've been happier with this product over Plastidip.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Apr 19 2015
    Quote Originally Posted by HazeMyth View Post
    Wow looks good !!! Thanks for the advice!!
    Apr 19 2015
    Quote Originally Posted by doug97gxe View Post
    Me too Doug! That's the problem. My winter set is not unique enough/too common and boring for my taste (no offense to anyone here)
    I would buy new winter tires (20") but my 19" only have 1 winter and I also just bought 2 weeks ago new winter tires for my girlfriend New Evoque Land Rover.....
    Nov 10 2014
    Apex, NC
    I've been debating the same also thought of some replicas from ECS for $500 for 4
    Sent from my iPhone8s using Tapatalk
    Present:
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    If you're going the plasti-dip route, be sure to take your time and put on plenty of coats. Too thin and it can be a real pain to remove.
    Also, if you don't use caution, you'll fit in well with all the boy racer Honda and Subie owners who consider plastidip a mod. #BecauseRacecar #Hoonigan
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Apr 19 2015
    You should get same style as my Black Satin wheels but with Silver lip instead. It would look wicked on your ride!!
    Nov 10 2014
    Apex, NC
    Lol ECS replicas is all I can afford right now
    Present:
    Veteran Member Three Rings jamin_00's Avatar
    Sep 14 2014
    Essex, UK
    Did mine a while back. Matt Black.
    Audi S5 V6T 3.0 - Black Edition - Stage 2 MRC Tuning - 480bhp 580nm
    Apr 19 2015
    [QUOTE=jamin_00;11247653]Did mine a while back. Matt Black.
    Looks great Jamin! Especially on 20"!
    Sep 30 2009
    b
    Coming from someone who has dipped just about everything.
    I hate it now. It looks especially bad on wheels. Unless you spend the money on the specialty cleaners (which are fucking retarded expensive) they are really had to clean of brake dust.
    They end being tainted brown after 2 weeks. You'll end up spending more time cleaning dip than a proper finish.
    I had a phase with dip and it can be fun, but it's basically a waste of time and money.
    Jul 17 2015
    Colorado
    ^ I've had mine dipped since September, and they still look exactly how they looked when I dipped them, and I haven't had to go out of my way to keep them that way. If I'm washing the car at home I soak them in simple green and rinse them. If I'm cleaning it at the local wash, I use the pre-soak foam and spray them with high pressure water. Evo wheels were dipped for 3 years and we never had an issue with the wheels browning.
    I find that people with the browning issue are usually over-thinking the process to clean plastidipped wheels. You shouldn't even need to touch them with a rag. Just make sure you're soaking them thoroughly with a non-abrasive cleaner, and try to use high-pressure water whenever you can.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Sep 14 2014
    Essex, UK
    Also had no issues with cleaning it. Did my diffuser also which lasted fine. Wheels I did not keep long enough to see if any issues arose. And if Flexidip is better, then give that a shot
    Front wheel dipped, rear powder coated just about to be plastidipped to show the difference.
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    Quote Originally Posted by SLU_S5 View Post
    Are you sure that hasn't already happened? I can't believe all the guys on here who spend 60-90k on a car and then use plastidip like it's the best thing ever. To each his own I suppose; I just think it looks cheap.
    Sep 14 2014
    Essex, UK
    So looking at the rim I posted above you think it looks cheap?
    Mate, you wouldn't even know it was plastidipped when it was on the car lol
    Apr 19 2015
    After reading all comments/advises on here I think I will finally go with Antracite plastidip color just like on this picture. I think it will be a good compromise between my Black summer wheels and 2 tones winter set.
    What do you guys think?
    Apr 19 2015
    Here's another look at the wheel
    Sep 14 2014
    Essex, UK
    Nice mate, go for it :)
    Veteran Member Four Rings paul.karroum's Avatar
    Apr 06 2015
    2023 Lexus RX
    New York City
    I had plasti-dip on my last car. For me it looked nice as I was spraying it and after it dried it started to look cheap and like crap. I suck at painting though. If you're good at painting then the plasti-dip should come out fine. My buddy did it and he's had it for a year now. Still looks glossy and nice. Bottom line is; if it sucks peel it off and write off the 30 bucks as a loss. No big deal.
    I do like the anthracite color though. Should look sweet if it's done right.
    Paul J. Karroum
    Brilliant Red B8 S5 6spd
    ST Coilovers, LED Interior lights, Extreme Spoiler lip spoiler, Stoptech BBK
    MSY3 | Mech Engineer | Chemist
    Instagram
    Previous:
    2004 Infiniti FX35 Silver
    2007 Audi A5 6spd Brilliant Red
    Apr 06 2015
    2023 Lexus RX
    New York City
    @jamin_00 that's insane how close they look. Powder is slightly more glossed but that still came out looking really good.
    Paul J. Karroum
    Instagram
    Previous:
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    I like the look of anthracite on your car. Another possibility would be to mask off and plastidip only the machined area of the wheel, keeping your stock color for spokes and barrel but changing the contrast on outer edge.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Veteran Member Three Rings Johnhanson's Avatar
    Oct 26 2013
    Regina
    If that's what a riced out civic looks like then I'll take a '96 EX with a fart can.
    I say go for it. Looks great.
    2013 Audi RS5 Coupe | Phantom Black | Everything except ceramics | Capristo | Eventuri | 15/10 H&R | Rotors when it's cold | V-Spokes when it's warm
    2015 BMW X5 35d Msport | it runs on kerosene | notsport | baby seat
    dead and gone.....
    2012 BMW X6 50i | it had a bike rack
    2010 Ram 1500 | hhhhemi
    2008 Mazda RX-8 | it go-karts
    2006 Infiniti G35 coupe | my lady
    1998 Eagle Talon esi | no turbo powers
    Nov 29 2009
    Miami / Florida
    Ya, the anthracite looks good, better than full black to me. Your car is already blacked out so it is a nice look. Go for it. Worst case you peel it off. At least when you peel off the wheels should be well protected to if you ever sell them.
    Oct 26 2013
    Regina
    Quote Originally Posted by dolphinaudi View Post
    People would probably request I burn in hell for suggesting this - but that color combo would look badass on an RS7 or S8
    dead and gone.....
    Jan 27 2010
    Cayenne%20X5
    Long Island, Queens, LA
    add me to the list of your winter wheels are better than your summer wheels and keep them as it is. for two reasons
    1. the rotors to me don't look good in a one-tone finish. the bare machined edge gives the wheel a unique and tasteful look and without the contrast it just looks like a dodge challenger 5 spoke.
    2. plastidip does NOT come off easily after months of being on a wheel..and will especially not come off easily after going through several winters. i ended up using paint thinner as a last resort on my old wheels to remove the plastidip and i'm pretty sure it took some clear with it as well.
    ig: gs.autogram
    Apr 19 2015
    Quote Originally Posted by johnhanson View Post
    people would probably request i burn in hell for suggesting this - but that color combo would look badass on an rs7 or s8
    sent from my iphone using tapatalk
    burn in hell lol
    Veteran Member Three Rings mcbuck's Avatar
    Mar 21 2010
    '19 Jeep Wrangler Unlimited Rubicon, '16 Grand Cherokee, '12 328 cab
    Charlotte-ish
    Not a fan of the summers, something about the red doesn't look right to me. But I'm not hating the plasti-dip on the oem rotors. I've PD'd wheels before and never had a problem taking it off, but the trick is to put it on thick to start with.
    I'm thinking about doing something different with mine, but don't know what color to go with Daytona grey. May play with a few different combos before I spring for new wheels - I don't have an endless supply like Mops
    BUCK
    2011 A4 quattro, 2.0T, A/T, Deep Sea Blue Pearl (my son's car, but guess who gets to work on it?)
    GONE 2013 RS5 Daytona Grey Pearl, X-pipe, 20% tint, Arc Audio/Alpine, interior/backup LED, 034 RSB, H&R sport, V-FF 103, 285/30 DWS06, Girodisc, Hawk
    GONE - B7 A4 quattro, 2.0T, 6MT, 250K....dropped, tuned, and everything else
    Jul 17 2015
    Colorado
    If you don't put the dip on thick enough it's such a pain to get off. Instead of peeling it off you have to soak it in tire blackener and then either scrape it off or use a high pressure sprayer, and it's a very messy process. I think it took us 7 hours to get the dip off of our wheels, because we had only put 5 or so coats on them the first time around.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Apr 19 2015
    Quote Originally Posted by mcbuck View Post
    I personally love the Red Lip. It match my Dk Grey/Red interior. I also love the Black Rotor with Silver lip. This can maybe a good option for you since you're not a fan or the Red.
    I also love the fact that these wheels are so rare! I get stop so many time by people, especially RS5 owner that tell me they wish they would have that wheel option when they purchased their car.
    My winter wheels are too common. You see so many A5/A4 with these and even some Volks sometimes...
    Jan 07 2011
    2013 C300 4Matic
    its common cause everyone likes em :)
    time attack strip only look good on jdm cars imo
    but to each their own. i approve of the antrhacite grey dip doe!
    Present:
    IG: bknewtype
    Apr 19 2015
    Not because everyone likes them because they come standard with any Sline package on A4/A5 and maybe soon with A1/A2/A3/A6/A7/A8/A9 LOL
    Glad you approve the Anthracite grey dip ;)
    May 21 2010
    Guys ,
    Thoughts?
    I plasti dipped my OEM for winter. Looks great and pretty easy to fix scrapes etc. Easy to peel off.
    Jan 07 2011
    2013 C300 4Matic
    lol false! its an option but def not standard. 950$
    actually dont know of anyone who really dislikes them. maybe ur the first
    Present:
    IG: bknewtype
    Apr 19 2015
    Don't dislikes them ,just find them common lol :)
