Results 1 to 15 of 15
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    need/want vag com scanner
    http://www.ebay.com/itm/VS450-Audi-V...275460&vxp=mtr
    is this good? can anyone link me to a scanner where I can read codes and even remove CEL etc.
    Nov 12 2015
    Oregon
    dont know if it is any good. Buy one of these....you wont regret it
    www.Ross-tech.com
    My build log
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    I can scan it for you
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Quote Originally Posted by VinnysS4 View Post
    www.Ross-tech.com
    That's a genuine VCDs, it's the canine cojones of VAG diagnostics leads.
    Mar 14 2013
    Quote Originally Posted by Lucca M View Post
    im moving next month, and I also want to have it just incase. I have an airbag light on since I changed my seats.. I apparently need a passenger airbag bladder to remove it.. (900 at dealer, 200 installation) what?! I would rather find a seat and just do it myself. any ideas
    Jan 17 2014
    New Jersey
    Just put a resistor on and it will go off. Oem seats? Do they have airbags?
    Insta: luccamentone
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    You need the genuine ross tech for the Hex-CAN B7's. I had the full version for my B6. But when I got the S4 no longer worked. Had to purchase the Ross-tech.
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Mar 14 2013
    From what Drive Auto Works in Clifton said, I need the pressure plate/passenger airbag bladder. I found the bottom section of an A4 seat that I can take it out of for $100 and just do the work myself if anything. Yes, they have airbags. It's because I have a B7 and I put the blue Recaro B6 seats in. The airbag system is configured differently according to a few sites I researched from.
    Jan 17 2014
    New Jersey
    Ah ok. Well if you dont care about airbags in the seats just install resistors.
    Insta: luccamentone
    Mar 14 2013
    Kind of dont, but god forbid something happened. Just because that one isn't active, it disengages all the airbags in the whole car. Don't want anything to ever happen and risk that.
    Jan 17 2014
    New Jersey
    Hmm im pretty sure if you put resistor on the airbag it will disengage only that one airbag. Why it would do it to all of them?
    Insta: luccamentone
    Mar 14 2013
    from what i've read
    http://nickscarblog.com/diy/how-to-i...-warning-light
    Jan 17 2014
    New Jersey
    Ahh i know what you mean now. Your seats are from b6 and you need that module to make it work. Im just thinking because when my new seats arrive they wont have air bags in them so ill have to put resistors on the plugs so air bag light doesnt come on. Basically what it does it tricks the computer to think that the airbag is still there and it works fine.
    Insta: luccamentone
    Jan 17 2014
    New Jersey
    Easiest way just find someone who sells his stock b7 seats after swap, ive seen some guys selling them for 50$ on here. My new recaros arent heated and ill be attempting to make them heated with oem controls
    Insta: luccamentone
    Mar 14 2013
    yeah, exactly, I found some on ebay for around that or higher but still good
