Page 3 of 3 FirstFirst 123
Results 81 to 110 of 110
  1. #81
    Veteran Member Three Rings Karbon's Avatar
    Oct 04 2016
    New York
    KW EDC Cancellation Kit + Mag Ride + Coilovers - any shop/manufacturer want to help?
    Maybe I'm going crazy. Seems like 248 is for the S3 and 370 is for the A3 ? Not 100 percent tho.
    2010 ZR1 - 9.5 @ 151
    2013 CTS-V - 9.8 @ 141
    2005 EVO - 9.6 @ 149
  2. #82
    May 24 2016
    Southern California
    Quote Originally Posted by Karbon View Post
    Maybe I'm going crazy. Seems like 248 is for the S3 and 370 is for the A3 ? Not 100 percent.
    Click that small [+] Show vehicle listing. Ours comes up there if you scroll.
  3. #83
    Oct 04 2016
    New York
    Quote Originally Posted by S3BURPS View Post
    You mean select the car individually ? If so I did and it's 248
  4. #84
    May 24 2016
    Southern California
    Weird. It's listed under the 370.
  5. #85
    Oct 04 2016
    New York
    So weird. Did you try it my way as well ? I could be wrong,I'm just trying to figure out which is correct lol
    I'm wondering if this is why some people are having problems and some aren't.
  6. #86
    May 24 2016
    Southern California
    Did it your way and 370 pops up still for me.
  7. #87
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    370 for me. It's what I was originally told to buy. It's also what KW asked me to ship back to them and sent me a new one of. Pretty sure if it was the wrong part KW would have called that out first in all my talks with them and all the tests they had me run.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
  8. #88
    Established Member Two Rings carlito.p's Avatar
    May 08 2015
    Vancouver, BC, Canada
    Just wanted to share a setup that worked for me without any codes thrown after a week and a bit of driving around town and some spirited weekend driving. I went with the H&R Street Performance coilovers + KW EDC Delete kit. I'm wound down pretty low too. I'm at 318 mm from fender to mid center cap all around. Haven't thrown a code once.
    Not sure if it makes a difference, but I had the KW delete kit installed about a week after the coils because I received them late. So I did live with the fault for about a week. Super happy that the KW kit is working... For now!
    Sent from my SM-N920W8 using Tapatalk
  9. #89
    Apr 11 2012
    Quote Originally Posted by carlito.p View Post
    Wow, that's awesome... how hard have you pushed it? folks can consistently get codes going 40-50mph around a loop ramp. if it's working for you, then that would make me think its not height related?
  10. #90
    May 08 2015
    Quote Originally Posted by will13k7 View Post
    I hit a bunch of on/off ramps this weekend at those speeds for sure.. No codes.
    The shop I frequent has installed same setup on 3 Golf R's and no faults. I was the first S3... So far so good.
    Just to confirm also, part # for my KW kit ends in 370 also..
  11. #91
    Oct 04 2016
    New York
    How does the kit work for some people and not others. Makes no sense at all lol. And Carlitos car looks slammed
  12. #92
    Apr 11 2012
    damn, you're a lucky guy, placing any bets this weekend?
  13. #93
    May 08 2015
    Haha. I should...
  14. #94
    Apr 11 2012
    I think you're onto something, it's not that we are too low, it's that we are not low enough! we gotta slam it like carlito! (carlito's car is looking good by the way)
  15. #95
    Oct 04 2016
    New York
    Lmao,There you go !!!
    Either that,Or slam it then wait a week to install the Kw kit. One or both of those worked :)
  16. #96
    Sep 28 2010
    NW NC / DE
    Damn that looks good! @carlito.p
  17. #97
    Oct 04 2016
    New York
    His car sits perfect. Lowest I've seen so far #Static
  18. #98
    May 08 2015
    Thanks Mops!
    For those wondering about FTG measurements, I'm 24"1/4 up front and 24"1/2 rear. Also running 12mm spacers up front and 15mm in the rear. No audible rubbing while driving, but I did notice a very faint rub line on the outside of my front tire top sidewalls, where sidewall meets tread. I'm considering going down to 10mm spacers up front.
    The H&R's, despite how low I'm sitting feel great! Firm enough in the corners and more aggressive driving, yet still comfortable enough around town and even over road imperfections. Super quiet too, but could also be because I replaced both front (with 034) and rear (with oem) strut mounts and bearings.
    My pregnant wife and 4 year old daughter have approved
  19. #99
    Oct 04 2016
    New York
    Next question is. Why aren't all the coilovers coming with camber plates for $1500 smh
  20. #100
    San Francisco, CA
    Because they can charge you an extra $500 for them. That's why.
    2019 GT3 Touring
    IG: brandongray
  21. #101
    Oct 04 2016
    New York
    Quote Originally Posted by phillyquattro View Post
    So they think lol
    I can buy a set of ST XTA coilovers with camber plates for the same price as B16s and any other comparable coilover :)
  22. #102
    Veteran Member Three Rings mossback's Avatar
    Feb 01 2015
    2017 Subaru Outback
    United States
    I just wanted to say< I have an 8S TTS and have the exact same problem. This really sucks as I take the car on the track, and need my TC off.
    2016 TTS
  23. #103
    Feb 01 2015
    2017 Subaru Outback
    United States
    To add: I just contacted iSweep from Japan who say they have a unit for MRC.
    I will be getting this ASAP, to give it a go, I spoke to Jerry at Neuspeed at length about it and it sounds like it works as advertised.
    http://isweep.jp/products/ecscanceller.html
    2016 TTS
  24. #104
    Nov 13 2009
    the OC, SOCAL
    got any more pics of the car?
    I'm interested to see how this color and wheels looks lowered. if you have more different angles that would be awesome.
  25. #105
    May 08 2015
    Quote Originally Posted by 949 View Post
    PM'd
    Sent from my Pixel using Tapatalk
  26. #106
    Apr 11 2012
    issue solved in another thread:
    http://www.audizine.com/forum/showth...ptions-Discuss
    basically, iSweep's works, KW's doesn't. There might be a way to code it out, but there is inconsistent feedback here so far. Also, if you get height sensor codes, your height sensor might be defective.
  27. #107
    Nov 13 2009
    the OC, SOCAL
    PM'd
    cool thanks for the link man. too bad your not local I would have given you wholesale on the kw suspension direct from the warehouse.
  28. #108
    May 08 2015
    ? I'm running H&R coils... But the KW delete kit..
  29. #109
    Nov 13 2009
    the OC, SOCAL
    oh my bad, i should have said h&r with the kw delete kit as i can do most brands.
    i always believe in paying it forward if i can.
  30. #110
    Nov 29 2019
    Just as an update, the issue still happens to this day. My MK7.5 R has the same issue which popped up on track. KW never seemed to update their logic.
    I'll try the arm bending and see if it works.
