Results 1 to 4 of 4
    Veteran Member Four Rings TMurt's Avatar
    Feb 01 2011
    Indianapolis, IN
    Unsolvable thermostat housing leak
    Hey guys,
    So I had a coolant leak back in may in my 2007 3.2 and the dealer replaced the thermostat housing and water pump. My car was up for sale for a while when we noticed another leak and dealer replaced the thermostat housing again (under repair warranty) citing a defective housing used in the original repair. That was on November 19, dealer inspected and found no leaks and car was barely driven until it was sold last Sunday. The new owner contacted me about a coolant leak and said he had it inspected and found the thermostat housing leaking again. So I have a couple questions now.
    Will the repair warranty be transferrable to the new owner?
    And what could be the problem. The odds of a brand new thermostat housing leaking after only 200 miles should be near zero, so what else could be causing the leak, yet continuously be diagnosed as a faulty thermostat housing?
    Thanks in advance!
    Current: 2010 Imola S4 Prestige 6MT
    Past: 2007 Audi A4 3.2 Quattro
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Quote Originally Posted by TMurt View Post
    Hey guys,
    Thanks in advance!
    I would assume that the warranty on the work would transfer to the new owner. they still performed the work, nothing changed except the owner of the car. although...... this is AOA....
    Senior Member Three Rings Khaotic's Avatar
    Feb 21 2011
    2001 Audi A4 Avant 1.8T Quattro
    Sweden
    EDIT: Nvm, noticed you're talking about the 3.2
    2007 Audi A4 Avant 2.0 TQ 6MT S-Line
    Exterior: Bi-Xenon Retrofit | 30% Tint | KW V2 Inox | 19" VMR 701
    Interior: LED Lighting | Black Headliner | RS4 Shiftknob | oCarbon Trim | TTS Steering Wheel | Audio build
    Engine: REVO Stage 2+ | STaSIS Exhaust | R.A.I HFC | Custom CAI | AWE FMIC | HPFP Stage 1 | RAI Catch Can | JHM Flywheel & Clutch | USP Metal Slave & Clutch Line | JHM SS Trio
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    It's possible they pinched the o-ring when they installed it...I did this and it leaked almost immediately. Or it isn't torqued properly. It should be relatively easy to determine where the leak is actually coming from...clean everything, go for a drive, see where it's wet.
    2005 B7 A4 2.0T | Brilliant Red | 6MT
