Results 1 to 6 of 6
    Established Member Two Rings SS1LE02's Avatar
    Aug 01 2009
    2009 CTS-V, 2006 Silverado 4x4, 1967 Chevelle SS convertible
    Minneapolis
    Trim pieces on bottom of fenders
    I don't have a fender off so I'm not sure how they attach. Are they just clips, or are the held on with a nut. Does the fender have to be removed to take off/install?
    Also, if anybody has a line on a facelift Santorin blue drivers fender in great shape let me know.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    There's a plastic nut on the backside that needs to be removed. The trim piece will then slide forward and pop out from the fender.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Good luck with not snapping any of those plastic tabs
    Aug 01 2009
    Minneapolis
    Quote Originally Posted by BaseDrifter View Post
    I figured. So fender needs to come off?
    Quote Originally Posted by adam044 View Post
    I'm sure Murphy's law will be in full effect.
    1999 Santorin Blue A4 5 spd Quattro
    May 18 2010
    Just pull the fender liner, no need to remove the fender.
    01 S4 2.7T: Stock
    Aug 01 2009
    Minneapolis
    Cool. Thanks for the tip.
