Results 1 to 7 of 7
    Dec 09 2015
    Deleted
    Audi S4 Look exhaust pipes
    Hello,
    first of all, sorry for my bad english knowledge.
    I want to exchange the rear pipes of my original mufflers from one pipe each muffler to two pipes each muffler like B7 S4 has.
    I already got an S4 rear diffusor with enough place for two rear pipes each side.
    Has anyone done this exchange and would recommend me some good pipes?
    Thank you!
    Audi A4 B7 3.2 FWD, Lightsilver, 7,5 x 17 S-Line Wheels with 20mm wheelspacers each wheel in the rear and 15mm each wheel in the front. Inside S-Line package with LED light.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Don't you know any EU companies doing this? All the American brands we use ship from U.S so it would be very expensive for you....
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Dec 09 2015
    Deleted
    Hello. Thank you for your reply. I have only found two suppliers here in Europe. Unfortunately it is not the quality I expect. So I hope someone knows an item that is from good quality (stainless steel) and good looking.
    Nov 07 2012
    Scotland
    Quote Originally Posted by Markus40 View Post
    Do you not have any custom places close to you? My local place did mine for less than half the price of a branded one.
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    Magnaflow dual tips should do the trick. And if you're a real perfectionist you can have a shop stagger the outer tips to flow with the rear lines of the car. Usually they'll just cut off the outer tips, shorten them and reweld back on to create that staggered tip look.
    2008 A4 2.0TQ Ti - 6MT
    1991 MR2 Turbo - 5MT
    1997 Pathfinder 4x4 - 5MT
    ~Marc
    Dec 09 2015
    Deleted
    @Ajax1976
    Thank you. That is exactly what I am looking for. Do you have any advice where I can order that pipes from picture number one online?
    Is that an carbon foil at the diffusor? It looks all very good.
    @ Quattrium MT6
    Thank you for your advice.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    @Ajax1976
    @ Quattrium MT6
    Have you tried amazon.com? If you just want quad tips then you can weld on basically anything.
    Maybe there is an amazon.EU for free shipping? Also try aliexpress.com and ebay.eu
    I'm sure any exhaust shop will have something available
