Results 1 to 4 of 4
    In, Out and Around...
    DX: Ticking Sound At Idle...
    Anyone on here able to diagnose a ticking sound on here? The 3.0t Q7 has a ticking sound from day one that sounds like a woodpecker stuck inside my fuel tank. It is coming from inside the left (driver's side bank) and it is only heard on idle but goes away if you give it a bit of gas. It is a rhythmic ticking and gets louder as the tank gets lower. I have to assume it is a failing fuel pump but would like to see if others had the issue. The vehicle has approximately 400 miles on it and I will be making an appointment once my schedule clears up. Thanks.
    Senior Member Two Rings AnotherJake's Avatar
    May 08 2014
    Nissan Frontier
    New Mexico
    You might want to post this in the B8 S4 section also for more eyes on.
    2013 S4 | Volcano Red | Black Leather/Alcantara | MMI 3G+NAV | DSG | B&O | Sports Diff | AWE Boost Gauge | Vag-Com | Stasis Full Exhaust | Roc-Euro Intake | Alu Kruez | CR-15 | Eurocode Sways & End Links | APR Stage 2 | AWE Coldfront | RS4 Grille | ECS Front Rotors | SS Front Brake Lines | Hawk HPS Pads | Neuspeed 18" RSe07 | 034 Trans/Diff/Carrier mounts
    thanks... will do.
    turned out to be fuel lines vibrating. fix took just a few moments. no issues.
