Results 1 to 26 of 26
    Aug 22 2012
    uk
    Advice requested - my S4 at Audi for > 1 month needing 2 replacement cyclinder heads!
    Guys
    I have a 2012 B8.5 S4 with 25000 miles and totally stock (no mods - ever!) and Full Main Dealer Service History.
    Over it's lifetime it's had 3 misfiring episodes; approx once each year. The issue was "resolved" by Audi on the first and second occasion by changing an ignition coil.
    On the third occasion (about 6 weeks ago) the problem started again; misfiring under WOT then EPC light would come on. Turning the ignition on / off twice would clear the issue for a while but quickly the problem returned. So back it went to Audi. This time they concluded the cylinder head was cracked (had it always been?). Had to wait 10days for a back order cylinder head to arrive. When changing the head they found another part needing replacing (some hose or other) - another 10 day back order. Finally they put the car back together and find it has an oil leak and have to order a seal. OK a bit frustrating but then things took a BIG turn for the worse. Whilst test driving the car before returning it to me, they claim that the camshaft in the new cylinder head seized, resulting in the new cyclinder head becoming distorted. WTF. So they now need to put another cylinder head in. Another 10d wait! So it's been at Audi over a month now.
    So thing is I'm no mechanic. I need to know what questions to ask and things to check before taking the car back. Could they have damaged other parts of the engine / car when the camshaft seized? What causes a camshaft to seize? Anyone experienced a cracked cylinder head or seized camshaft before? Any insights or suggestions here massively appreciated - I'm feeling well out of my depth. The only plus is it does have a 4 year Audi warranty.
    Looking forward to receiving your advice - thanks
    Last edited by guestlinger; 12-10-2015 at 09:59 AM. Reason: seized / camshaft changes
    Audi S4 Avant, 2013, Glacier White, DSG, Black Edition, 5 arm 19" Titanium rotors, ADS, Sports Diff, variable suspension, Black / silver alcantara, 3G Nav plus, Audi connect, B&O, side assist, parking camera, rear air bags
    Jul 21 2004
    South Florida
    I'm guessing they said/meant the camshaft seized. It could have been someone put things back together wrong or another part failed.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    trade it in, you don't want that thing or want to deal with that thing long term, there are plenty of other s4's out there with no issues.
    Stage 1 more than you RS3
    Mar 01 2006
    Kitchener, ON
    who is doing the work? Audi? I assume from the posting
    Take it to a different dealer
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Aug 22 2012
    uk
    thanks Mike - Ive made the corrections
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I seized and snapped the camshaft on one of my old Mazda heads by reusing the cams cap from the old head on the new head. Turns out the cam caps are uniquely machined for each head. But who knows what happened with yours. Even accidently switching one of the cam caps to a different position could cause this issue.
    -Alex
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Quote Originally Posted by o1turbo30v View Post
    That is actually not a terrible idea. Audi is known to give really high trade-in values when something major (e.g. DSG) fails.
    Aug 22 2012
    uk
    all done at Audi main dealer.
    Quote Originally Posted by RudyH View Post
    Aug 22 2012
    uk
    the new cylinder head apparently inclded all new components ie camshaft valves etc). I dont think they used old parts from the cracked cylinder head if thats what youre thinking??
    Quote Originally Posted by fitzydude View Post
    -Alex
    Jan 10 2007
    VA
    As long as they're fixing it, there's not much you can do but sit and wait however inconvenient it is. When they're done make sure everything was documented in detail, including the fact that they 'fixed' it yet it failed on internal test drive and had to be fixed again. This detail will be helpful if the car continues to have problems and you end up talking to Audi Corporate about a buyback or other remedy.
    Otherwise just drive the crap out of it to uncover any other issues and to make sure its solid before your warranty expires. If it does have more problems, I'd look to trade it and see if the dealer or Audi can hook you up considering how unreliable your particular car has been.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    This makes no sense. The head is the issue, and is being replaced.
    Why would he not want the car?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 09 2008
    Quote Originally Posted by LINDW4LL View Post
    Because he has no idea what anything under the hood is and just gets scared.
    OP, you'll be fine. If anything the cam was probably improperly installed or they started it dry.
    Let them fix it. When you go to pick it up I'd check for hose and electrical fittings. But really if you aren't familiar with this kind of stuff you aren't really going to be able to find anything. Just drive it home and bring it back if there are problems. It's just a head swap.
    The Awesome™
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    You don't want to keep this car.....what's the chance that the dealership mechanic is doing as good a job as the Audi engine factory........the evidence tells me they do not know what they are doing.......
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    First off. You should look into your country's lemon law's if there are any and how they are written to possible help you. If this car was in my state this would fully qualify for lemon law and theirs nothing they could really do about it. Audi would have to buy the car back according to my states law. I would look into and start to question this and possible pursue buyback
    Jul 21 2014
    United States
    If I had to guess -- they didn't get the timing chain/cam gear timed properly and bent valves or cracked the new head. I'd be inclined to trade it in for a new S4.
    Nov 10 2014
    Apex, NC
    i had something similar happen on a bike motor.. it was user install error .. bike was never right after.. motor eventually grenaded
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Aug 22 2012
    uk
    Thanks all for your suggestions. It seem there's 2 schools of thought .... either a) it's just a cylinder head - it should be ok to fix or b) don't risk it - there maybe other issues following a double cylinder head failure.
    I have loved this car - spec'd it out just perfect for me and was hoping to have a few lease free years ahead of me
    If I trade it will Audi value it as a "normal" 25000 mile, 3 year old car or are they likely to offer me less because of the cylinder head issues? What do you guys think?
    Oct 09 2008
    Quote Originally Posted by S4'ed View Post
    Are you serious? You act like a cylinder head requires an assembly of world class neuro surgeons
    The Awesome™
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Quote Originally Posted by JoshDub View Post
    haha that's pretty funny. to be fair, he makes an unusually unique point that I never would have thought of and although extreme after re-reading the o.g. post I think he may need to have the car repaired provided audi is covering under warranty and sell it - or ride out the warranty and see if they finally got it right this time. I wish I could give some technical advice but it's beyond me, sure would be nice if they replaced the motor but I doubt that's even a consideration unless the cam shaft seizing is a catastrophic metastasizing issue.
    Feb 06 2012
    Allentown, PA
    It's not that it requires a lot of skill it's wether you would feel comfortable having 50% of the engine replaced on a relatively new car. Why keep it would be a better question. It's a 2012 with 25k on it, not acceptable to me by any standard. There are plenty of higher mileage s4's with no issues clearly this engine was built at 4:59 on a Friday.
    Aug 22 2012
    uk
    so do you guys think it's more likely that a) the second cylinder head was faulty and that's why the camshaft seized or b) the repair was bodged by Audi and that's why the camshaft seized?
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    Quote Originally Posted by guestlinger View Post
    Bodged repair.
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I have been out of my car for 2 months and still waiting, all for a bad CAT. Should never of taken it to Audi for the repair....
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Nov 10 2014
    Apex, NC
    i would say keep it till your warranty runs out.. as long as audi is footing the bill then don't worry about it
    Present:
    Mar 10 2015
    New England
    It depends on the issue, but Audi usually gives ridiculously good trade-in values on cars with major problems; the best example is DSGs crapping out.
    The car could certainly be fine, but I would probably try to a great deal on a new car if I were in your boots.
    Sep 24 2014
    Central NJ
    You paid for a premium product, and now you have some guy, with unknown skill, repairing your almost new engine, and they botched the job already once.....do you really think they sent a defective head assembly from the factory?????
