Results 1 to 18 of 18
    Established Member Two Rings jesse_gabriel's Avatar
    Dec 09 2015
    california
    Blown itercooler twice!?
    Okay so I recently replaced the turbo, kept it stock with another k03 and about 3 days into driving in 1st gear at probably 4,500 rpm I here the loudest bang I've ever heard come from a car and then it died, I could get it running for a few seconds and I could here air leaking by the bumper on the drivers side. Come to find out that the bottom plastic piece of the intercooler blew off of the aluminum fitting? I thought it was just an old intercooler so I got a brand new one and not 10 minutes into driving it happened again! Someone help, this is a very rare problem from what I am told and I don't know what to do
    Dec 09 2015
    california
    Maybe I screwed something when installing the new turbo?
    Veteran Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    swfl
    Did your intercooler end tanks blow off or did they charge hoses blow off the intercooler?
    2.7 swap in progress
    Dec 09 2015
    california
    The bottom Piece blew off, the price that is actually part of the intercooler
    Jan 06 2009
    Is the brand new one genuine Audi?
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Dec 09 2015
    california
    It is brand new but not from Audi, even so it really shouldn't go out in 10 minutes right?
    Jan 06 2009
    I can make you one in my garage. I will guarantee it to last 11 mins.
    You should contact whomever you bought it from or the manufacturer directly and ask them what the eff!
    B7 2.0t
    Dec 09 2015
    california
    That's just not it, it seemed like a quality intercooler for the most part, you don't think it's strange that it went out the same way as the original, right after I changed the turbo? I just think something else is wrong
    Dec 09 2015
    california
    Heres a link to the picture, this is the stock pne but the same thing happened
    Jan 06 2009
    Might be related, might not be.
    Why did you replace the turbo?
    What tune do you have?
    What boost pressure are you seeing?
    Is your diverter valve functioning?
    B7 2.0t
    Veteran Member Three Rings maurizio's Avatar
    Sep 23 2005
    '09 Pilot
    Lake county, IL
    your bottom end would go boom before the end caps on the intercooler pop off.
    "Are you actually asking that question.. Just don't even post on my thread. why do I need to lie on an Audi forum about me fucking two bitches at once. (not literally) yes i did, you are late to the party.
    and this thread has ran out of gas. I just wanted to tell people about my experience I had 2 nights ago and felt like sharing it with my fellow B6'ers. And I thank the people who didn't hate."
    Dec 09 2015
    california
    I replaced the turned because the old one was leaking pretty bad and I have no tune. I dint know how to check the boost nor the diverted valve
    Dec 09 2015
    california
    And that's what I thought but that's not what happened
    Feb 12 2008
    Michigan
    Perhaps there's bad motor mounts or something and there's enough flex that it rips the bottom of the IC off
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    What is your boost gauge reading or spiking at? My stock side mount held 25 psi just fine before I upgraded to a FMIC. We need more details
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Dec 09 2015
    california
    I don't have a boost gauge, the car is 100 percent stock
    Aug 30 2013
    Rockville, MD
    I had a sort of similar problem with boost spikes when I replaced my smic with a front mount, hoses kept popping off. Without some way to measure boost - vagcom, boost gauge - its gonna be hard to say whats wrong over the internet.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You need to check on the two things I mentioned in your other thread: Clicky click® Excessive boost can definitely cause issues with the OEM intercooler. The end caps on mine started leaking heavily after a few years of running 22 psi of boost. Alex (alexza4) actually blew the end cap completely off of his OEM intercooler with a K04.
    You need to find a way to get a measurement on your boost. A boost gauge would be the best way but there are other cheaper options. If you have an Android cell phone an ELM 327 Bluetooth OBD2 transmitter coupled with a TorquePro App will give you a general idea as to your boost levels. Total investment will be under $20. It isn't a substitute for a gauge but it will definitely help you determine if your N75 and or waste gate are functioning properly.
