Results 1 to 13 of 13
    Active Member Two Rings TC315's Avatar
    Dec 07 2014
    Upstate NY
    US MILL WORKS front license plate bracket - loose
    What's up guys. I recently purchased a standard bracket from US Mill Works for my car and can't seem to get it on there tightly. Not sure if there is something wrong with my tow hook slot or I'm just incompetent..
    My main problem comes from when I screw the bolt into the slot. No matter how much I screw it in there, it still wiggles around left and right and my license plate ends up sideways. Is it possible for the inside of my took hook slot to be stripped? I ordered the right bracket for my car so I don't think its because the screw is too small or anything like that.
    Has anyone else experienced this problem? Looking for suggestions on what to do. I thought about putting some glue on the screw before installing it but I don't want to do anything too permanent if I don't have to.
    Thanks in advance.
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    I hope this isn't the case with the one I ordered this week! But, have you tried plumbers tape? That should tighten up the hole and threads
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Does the tow hook that came with your car fit properly, or is it also a 'sloppy' fit?
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Quote Originally Posted by TC315 View Post
    Thanks in advance.
    Aight I know that this serious but I read this and couldn't help but LOL. Sounds like you're making a blue movie man.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Quote Originally Posted by LYKUNO View Post
    +1
    Don't use glue or plumbers tape. You'll never get the thing out if and when you need to (which is typically during an emergency).
    Mine went on easily... make sure you're following his directions as well... you can tighten it by hand only so far... then you have to put the front bracket on and tighten that and use that to then twist the bolt in further to get it snug... He has a vid on his web site showing how to do this... You might just not be installing it properly.
    Dec 07 2014
    Upstate NY
    My car didn't come with a tow hook as far as I know. I purchased it used and one wasn't included
    Dec 07 2014
    Upstate NY
    Quote Originally Posted by MrFunk View Post
    +1
    Yeah I'm trying to avoid that. And I've watched the video it seems simple enough, I don't know what I could be doing wrong. Everything else fits snug besides the main screw. I've tightened it by hand and then used pliers to get it even tighter and its still loose.
    How much space is there between your plate and the front of your car? When I screw everything in my plate is basically touching. I feel like that shouldn't be the case. There really isn't enough room for me to rotate my plate to further tighten the screw like you said... if that makes sense
    Senior Member Two Rings mavz's Avatar
    Apr 06 2015
    I was able to screw mine in perfectly fine and it's tight (that's what she said :P)... So when you screw it in, does it never feel like it can't go anymore or something?
    Gone: 2013 Estoril S4
    APR - AWE - Vorsteiner - Continental - ECS - Akebono - JHM
    Apr 04 2012
    MSP
    It should be in your trunk in the foam cover over your spare tire.
    If it is not there then I am willing to bet it was damaged while the car was being towed out of a ditch or similar. I'd suggest trying your US Mill bolt in your rear tow hook sleeve and see if it's snug... if yes then I'll bet your front sleeve was damaged... Was the car ever in an accident?
    Apr 04 2012
    MSP
    If you are having no luck with the tow hook you can also use this for your license plate... Just affix it to you front grill centered....
    http://www.amazon.com/gp/product/B00...ilpage_o00_s01
    Dec 07 2014
    Upstate NY
    Quote Originally Posted by mavz View Post
    hahaha and no the opposite. I feel like I could keep turning it for an eternity and it still wouldn't be enough
    Dec 07 2014
    Upstate NY
    Na no accidents. I'll try this though, thank you!
    Apr 04 2012
    MSP
    Well I'm betting the previous owned used it and damaged the threading... I'm not a big fan of the tow hook plate look either - even though I ran one myself...
