Hi guys, I am new to this forum as i just purchased an audi a4 2009 cabriolet 2.0T quattro S-line with navigation (damn thats long).
The car was in a front end collision, and i just had it all repaired.
The driver steering and knee airbags where the only ones to deploy.
I went ahead and got a used steering with airbag, clock spring and new knee airbag. I purchased a new (used) airbag module as well but have yet to install it. I also bought the vagcom as i read that i can reset the airbag module up to three times before it needs to be replaced.
Well i went into the setting, i cleared all the fault codes.... and well, the airbag light is still on... can someone please help me.... Will the codes go away if i replace the airbag module? Do i need to change something else in the car? None of the seatbelt are locked.
This is what i get as faults (NOTE I TRIED ERASING THE CODES MULTIPLE TIMES AND IT ALWAYS COMES BACK):
Wednesday,09,December,2015,21:04:17:54881
VCDS Version: Release 15.7.2 Running on Windows 10 x64
www.Ross-Tech.com
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Control Module Part Number: 8H0 959 655 H HW: 8H0 959 655 H
Component and/or Version: Airbag 9.42 H01 1830
Software Coding: 0132105
Work Shop Code: WSC 00672 785 00200
Additional Info: 8H0910339B BF-Gewichtsens. H02 0020
Additional Info: Geraet 00200
VCID: 3F8D8FF96EABDDC652-806A
5 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
