    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Podi Gauge Questions
    Got my boost gauge installed recently, and wondering if anyone has come across the issue of their remote not working. I swapped the batteries and all and still no signal. Maybe its something with the gauge. Also, is it normal for it to rattle when the needle moves?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    Rattles are normal...its the stepper motor in the gauge receiving different vilatge from the pressure sender.
    Remote...if its nit working check battery otherwise...make sure you point the remote straight at the gauge.
    Make sure you read the instructions tegarding how to change the values from the gauge
    Jan 24 2013
    Chicago
    Does anyone have a PDF of the instructions?
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    Put steering straight. Put the remote on the top of the steering (on the air bag section ) in direction of the pod. Press or long press turbo icon.
    The angle is very sensitive.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by Denio24 View Post
    Contact Winston at podi with your questions. He is more than helpful
