Hey guys,
Just been running through a few tests on the build since Im approaching the 4000 mile mark. Can anyone confirm if these numbers are low for a built motor with 9:1 compression? Obviously I cant use OEM as a guide. I have two questions/ hunches. Car burns a decent amount of oil. Not enough to smoke tho....(pretty sure its a few leaking valve seals) I have a used head with no idea how many miles are on it. It has new seals but valve guides could be bad. I plan to build another one once I money up again. Oils fine and coolants great. So skip the head gasket.
Compression Test: (turned over 7 times)
#1 = 142psi
#2 = 142psi
#3 = 147psi
#4 = 150 psi
(note for future readers.. these numbers are with the throttle plate closed- must be open while testing) my bad...
Leakdown Test: (if i remember right after 1 min with 120psi)
#1 = 14%
#2 = 25%
#3 = 15%
#4 = 14%
Second question that I have is that my coil pack wire harness had the dreaded cracking last week so I replaced them with a OEM overlay harness. Everything's working fine but I am getting a miss fire at 20 psi. I could easily go 24 psi with never a miss fire after the build/tune. I changed the plugs from NGK-BKR6E-11 to NGK-BKE7E. Made a small difference but still does it. Always cylinder 2 and doesn't move with the coil pack. Thinking about just wiring the new harness right to the original harness. Just going back to what worked....
Last but not least... if you have anyone selling components to build a head or have a head that's built they wanna sell let me know please. :)
Relevant MODS
2.0l stroker - 058 Block
2000 converted to 2001 for Maestro 7 (MAF less)
JE Pistons 9:1
Scat Rods
ABA Crank
Stock AEB Head (slightly ported and gasket matched)
Walbro FP
Injector Dynamics 1000cc
GT3071r
Treadstone SS Manifold
Custom 3" exhaust - catless
Tial 38mm with (large blue and small red springs)
Tial BOV Q with -10.00 psi spring for "-16in/hg to -19in/hg vacuum pressure"
2.0 coil packs
NGK-BKR6E-11 (.44 gap) or NGK-BKR7E
Hallman Pro Kit Boost Controller
