Results 1 to 22 of 22
    Dec 09 2015
    Washington
    Exclamation Need help with CEL.
    Hi everyone,
    I'm new to this forum and recently joined as I need some assistance with fault codes on my 2010 A4.
    I'm not very mechanically smart but I'm scared to take it to a dealer right now as money is tight (baby).
    The other day I turned my car on and it started idling rough. The car would shake and you could hear it in the exhaust pipe.
    The CEL came on the next day along with the EPC light. The car will not start now. Everything clicks but no turnover.
    I pulled VAG COM codes below for the engine. I was going to try and replace the sensors but I'm scared this might be more serious.
    Please help.
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    33-Flux Capacitor -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AA HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H17 0005
    Revision: E1H17---
    Coding: 0104010A190F0160
    Shop #: WSC 02145 785 00200
    ASAM Dataset: EV_ECM20TFS8K2907115AA A01006
    ROD: EV_ECM20TFS0118K2907115AL.rod
    VCID: 6ED3283AB137086E76F-803B
    7 Faults Found:
    4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 00 [237] - Incorrect Correlation
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 126607 km
    Date: 2015.12.04
    Time: 11:12:45
    4010 - Idle Control System
    P0506 00 [101] - RPM Lower than Expected
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 126607 km
    Date: 2015.12.04
    Time: 11:12:20
    4054 - Cylinder 1
    P0301 00 [237] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 126607 km
    Date: 2015.12.04
    Time: 11:13:09
    4060 - Cylinder 3
    P0303 00 [237] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 126607 km
    Date: 2015.12.04
    Time: 11:13:09
    4063 - Cylinder 4
    P0304 00 [237] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 126607 km
    Date: 2015.12.04
    Time: 11:13:09
    4057 - Cylinder 2
    P0302 00 [237] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 126607 km
    Date: 2015.12.04
    Time: 11:13:09
    4051 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [237] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 126607 km
    Date: 2015.12.04
    Time: 11:12:18
    Readiness: 0000 0000
    Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
    Part No SW: 8K0 927 158 J HW: 0B6 927 156
    Component: 0B6 20TFSIUSA H05 0009
    Revision: --H05---
    Coding: 001012
    ASAM Dataset: EV_TCMAL651 A01006
    ROD: EV_TCMAL651.rod
    VCID: 3D71DF76ACD1A3F6BF5-8068
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
    Component: ESP8 quattro H04 0030
    Revision: -------- Serial number: --------------
    Coding: 150D18
    Shop #: WSC 02391 823 56573
    VCID: 7AFB146AF57F54CEDA7-802F
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Looks like you're close to 80k miles on the car. Could be either the G28 (cam position sensor) or the G40 (engine speed sensor, I think the crank position sensor?) going bad on you. That would explain why every cylinder is misfiring. Maybe someone here knows how to test each sensor to see if it reads okay...
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Start by changing out your spark plugs and ignition coils (very easy), then clear the codes and see if they stay away,
    P0016 00 [237] - Incorrect Correlation, 4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28), is not good, incorrect correlation can mean a serious timing issue.
    http://wiki.ross-tech.com/wiki/index...0/P0016/000022
    Stage 1 more than you RS3
    Dec 09 2015
    Washington
    I had a 75k done it and I believe they changed the plugs already.
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    did you figure it out? hopefully its not a failed timing chain tensioner?
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    Dec 09 2015
    Washington
    I'm not very savvy when its comes to engines. I was hoping it would be a simple sensor that needs to be replaced. This code though to me suggests something else could be wrong.
    I may need to end up taking it in because I have no idea how to mess with it.
    Do anyone else have any thoughts on this error?
    My symptoms are identical to these but the code is different.
    http://www.a4mods.com/index.php?page...eedsensor.html
    Feb 06 2012
    Allentown, PA
    Take it in, it's worth paying the $120 diagnostic fee, especially if you have a baby, I doubt you have the extra time to track down and research this fully.
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    You clearly have an issue with your Flux Capacitor.....wait wut? Only way to fix is to crank it over 88mph. I can't be the only one that noticed this.....
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Dec 09 2015
    Washington
    UPDATE:
    I had the car towed into Audi Dealer and there is a timing issue going on. Audi is still looking at it but they say it's likely a new engine will be needed.
    This appears to be the issue
    http://redlinespeedworx.com/2-0t-tsi...chain-failure/
    Lucky for me I was still under CPO Warranty. I'll update the thread as I get more info.
    Dec 09 2015
    Washington
    UPDATE 1:
    Audi approved a new engine so that's nice at least. Avoided a very expensive repair.
    My dealer contact says it looks like the timing chain stretched. Is that even possible? They saw wear on the cylinder head where the pistons were hitting valves.
    Apr 19 2014
    Long Island
    Quote Originally Posted by Hatch View Post
    UPDATE 1:
    Thats crazy at least it's being covered by your cpo
    Always makes me double think keeping the car outside warranty
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Well shite. Sounds like it's time for me to get the timing chain service done.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Apr 19 2014
    Long Island
    Quote Originally Posted by blbroo View Post
    How many miles you have?
    So much for this being a "lifetime" part
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by homelessNY_LI View Post
    96,000
    Dec 09 2015
    Washington
    For reference I have roughly 78k on mine but it should of lasted longer than that.
    Oct 26 2012
    St. Louis, MO
    The tensioners are the problem, I think. There is a revised one that doesn't fail, but I might as well do a full chain and tensioner swap if I am getting in there. However, if I can get a dealer to do it for around $1K and give me a loaner, I'll go that route vs just $600 for parts.
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    33 lmfao!!!!!!
    Pedal Responce first responder.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by 4ringnut View Post
    33 lmfao!!!!!!
    I saw that too when he posted originally. Looks like ross-tech sneaks that one in on all scans. I wonder, though, if there is a vag-com mod to enable it.
    Apr 19 2014
    Long Island
    33 lmfao!!!!!!
    Did I miss something?
    Oct 26 2012
    St. Louis, MO
    Look at the original post, item 33
    Apr 19 2014
    Long Island
    Lol, I didn't bother to read the scan that through. That's funny
    Senior Member Three Rings slacktide's Avatar
    Mar 01 2015
    Seattle WA
    UPDATE 1:
    Sort of. The links of the chain don't actually "stretch" but a small bit of wear happens at each pivot point, and when you add all the wear up, the total length of the chain increases. Many mechanics just call this chain stretch. Same deal happens with motorcycle drive chains. The tensioner is supposed to mitigate this, but here are known issues with the tensioners in our engines.
    1993 Audi 90 Quattro 2.8 5MT - Sold with 245,000 miles on it.
    2002 Audi A4 Avant Quattro 3.0 6MT - Retired commuter, Dog Car, Costco runner, Snowmobile.
    2014 Audi S4 Quattro Sport Diff 6MT - Daily Driver. CR-15, Chipwerke, minor cosmetic mods. Eventually I'll get around to the audio build.
