Hi everyone,
I'm new to this forum and recently joined as I need some assistance with fault codes on my 2010 A4.
I'm not very mechanically smart but I'm scared to take it to a dealer right now as money is tight (baby).
The other day I turned my car on and it started idling rough. The car would shake and you could hear it in the exhaust pipe.
The CEL came on the next day along with the EPC light. The car will not start now. Everything clicks but no turnover.
I pulled VAG COM codes below for the engine. I was going to try and replace the sensors but I'm scared this might be more serious.
Please help.
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
33-Flux Capacitor -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AA HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H17 0005
Revision: E1H17---
Coding: 0104010A190F0160
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TFS8K2907115AA A01006
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 6ED3283AB137086E76F-803B
7 Faults Found:
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [237] - Incorrect Correlation
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 6
Mileage: 126607 km
Date: 2015.12.04
Time: 11:12:45
4010 - Idle Control System
P0506 00 [101] - RPM Lower than Expected
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 126607 km
Date: 2015.12.04
Time: 11:12:20
4054 - Cylinder 1
P0301 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 126607 km
Date: 2015.12.04
Time: 11:13:09
4060 - Cylinder 3
P0303 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 126607 km
Date: 2015.12.04
Time: 11:13:09
4063 - Cylinder 4
P0304 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 126607 km
Date: 2015.12.04
Time: 11:13:09
4057 - Cylinder 2
P0302 00 [237] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 126607 km
Date: 2015.12.04
Time: 11:13:09
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [237] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 126607 km
Date: 2015.12.04
Time: 11:12:18
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 J HW: 0B6 927 156
Component: 0B6 20TFSIUSA H05 0009
Revision: --H05---
Coding: 001012
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 3D71DF76ACD1A3F6BF5-8068
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0030
Revision: -------- Serial number: --------------
Coding: 150D18
Shop #: WSC 02391 823 56573
VCID: 7AFB146AF57F54CEDA7-802F
