Results 1 to 26 of 26
Thread: DSG Tune
    Deactivated Three Rings
    Aug 24 2015
    DSG Tune
    Need everyone's opinion: is the DSG tune alone worth getting? For those that have had it, does it make the stock S4 a more enjoyable ride when smashing the gas pedal? I've had my ride for 2 months and I'm already bored.
    I need honest opinions because I am on the fence about buying the TCU tune. I don't want Stage 1 just yet...
    Thanks for the replies.
    Sent from my iPad using Tap,Tap,Tapatalk
    Veteran Member Four Rings Pilfer's Avatar
    Dec 13 2012
    To the Bay Area
    The DSG tune from APR is fantastic, the car shifts much more aggressively and the extra rpm's you can reach feel and sound phenomenal with an exhaust an intake. Ultimately though if you're already bored nothing will help you lol. I was starting to get bored with my car from about the same time of ownership you are. Did lots of modifications and still didn't keep it for much more than two years. You should get stage 2 or at least stage 1 with the TCU tune though.
    996
    Model Y
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Yea it is if u value....higher rev limit, swifter shifts, optimized shift maps, ability to disable auto shifts in manual mode, displaying actual gear in D/S mode, raised Launch control limit and overall smoother shifts.
    However what makes it fun is at least a stage 1 tune...so I'd wanna get that.
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Aug 24 2015
    Thanks for replies so far. I was thinking about squeezing the power out of Stage 0 as much as possible before going Stage 1 maybe in the Spring after the snow melted. I just feel that the dual clutch programming can be better somehow...
    Mar 21 2015
    Quote Originally Posted by jimblkmazda View Post
    You're only going to squeeze about 10 horses out of stage 0 with an exhaust and intake. Time to take the leap.
    Aug 24 2015
    That's true, but I meant I want to FEEL the power that's already there. I want better lateral g's :)
    I think I'll take the leap next year; soon.
    Mar 21 2015
    ^suspension mods
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by Pilfer View Post
    ^^ This. Just go all-in. You'll thank us later. Completely different car.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Aug 24 2015
    Quote Originally Posted by pdqgp View Post
    Starts to get pricey. I need to pay off almost sixty thousand dollars man. So you're sayin' the TCU tune is worth the one thousand dollars?
    Mar 21 2015
    Pay to play, expensive car=expensive mods.
    Mar 09 2014
    Boston, MA
    haven't had the dsg tune yet... but after 3 months of ownership, i went directly into APR stage 2 + suspension goodies. Its a completely different car.
    2018 C63S Coupe
    2012 C63 Coupe (P31 Package)
    2014 E350 Coupe
    2013 S4
    2009 C300
    2006 350z
    1991 Mr2 Turbo
    2001 Civic
    Aug 24 2015
    ^suspension mods
    Which ones you recommend like?
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    pretty sure you can not just get a DSG tune without at least a stage 1 ECU tune. they are tied together. I know GIAC is for sure. so is EPL's.
    Aug 24 2015
    Quote Originally Posted by onlyaudis View Post
    I read goapar.com website. Looks like they can take your money with just the DSG tune.
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    I would advise going all in if you get bored quick like me. In my Previous car I went Stage 2+ at a month of ownership and had to go full on build with bigger turbo after a year because of needing more. So this time I am waiting it out as long as possible. May jump on the EPL group buy though if it gets to the sweet spot
    Aug 24 2015
    Yes, Turbos are insanely addicting making you want more and more power :)
    Nov 16 2015
    DFW
    Well voiding all warranty on a car so quick was the biggest mistake ever! I lost so much money on repairs and rental cars that I want to puke every time I think about it!
    Mar 06 2015
    Columbus, Ohio
    I wouldn't get it stand alone. Not sure you'll see the most benefit there. I can't say that for sure as I went Stage 1 & DSG at the same time. One month later moved to Stage II.
    I will tell you that while it's pricey for all of it, it transforms the car performance wise. Again, completely different car. With just a few grand you're leaping a 4,000lb car into the low 12's which even by today's standards is great considering it's not a stripped down car.
    Mar 06 2015
    Columbus, Ohio
    The reality is though the bang for the buck here isn't that much really. Especially when you compare it to what it would cost to modify other cars to get to the same performance levels or to buy a car that can run low 12's and have all that the S4 offers.
    Feb 01 2015
    20ae GTI 1.8BT, CBR F4i, Speed Triple R
    Lancaster, PA
    DSG Tune
    I can't say I got a lot out of the TCU tune from features that will be usable without an ECU tune. Shifts were not super improved, marginally better I'd say, but coming from the A3, this DSG felt like it was already tuned. Selectable launch control isn't going to be a factor without more power. The shifts aren't noticeably quicker. The main reason I got it was for the extra rpm up top but I'm not sure you can rev that high on stock program, anyway. That would be worth checking into or I'd go straight stage 2 and then TCU tune, if not all at once. The pulley doesn't give a whole lot over the stage 1 and for avoiding the price of reflashing, it makes more sense, to me anyway.
    Mar 21 2015
    I agree totally. It doesn't make me happy either. I came from a very nice tuned Subaru that didn't cost no where near as much.
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    APR will make a DSG file to work hand in hand with the stock ECU. This way you see the benefits of the DSG tune without adding power to the engine. Definitely recommend it if you're not quite ready to tune the ECU and want to spend some money. But, if you end up doing the ECU the DSG is a must in my opinion. Without a doubt worth the money.
    For suspension, A Eurocode Alu Kreuz and front/rear sway bars with end links are a fantastic upgrade if you aren't looking to change the factory shocks and springs. A good set of coilvoers are going to be the most noticable difference, but also the most expensive.
    If you have any questions feel free to reach out to me via PM or e-mail
    Greg : [email protected]
    Aug 24 2015
    Thank you all for the candid feedback on this topic. Much appreciated.
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    Quote Originally Posted by GRUMPY-S4 View Post
    if i may so ask what was some of the issues that you had?
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Feb 20 2006
    NC
    Jump on the EPL Group Buy, Stage 2 + DSG tune will be under $1500 if we get 6 more people!
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Aug 24 2015
    Quote Originally Posted by scottycs View Post
    If it drops to $750 if we have 15 or 20 people, I might seriously consider buying it and holding on until 50,000 miles 3 years later to install it :) :)
