Results 1 to 14 of 14
    Veteran Member Three Rings skhan91's Avatar
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    will i need a DRC recharge?
    question folks!
    im planning replacing the front two shocks on my DRC as one of them is leaking.
    will i need a recharge for the DRC through an Audi dealership afterwards?
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    Pretty sure you do! Also, what is your reason for not going with a high end coil setup like Ohlins, Bilstein, or KW? I switched over and never looked back.
    Veteran Member Three Rings Reggie's Avatar
    Feb 27 2005
    2014 SQ5 & 2015 RS5
    Fort Collins Coloardo
    Quote Originally Posted by Seattle squash View Post
    Some of us (many actually) love how the DRC works - it is a great solution for street use and still great for track use.
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    I am getting a good deal on the front two struts at about 1/12th the cost of a decent coilover system. the only reason im doing this is because the front right strut is leaking, otherwise im fine with the DRC really, not tracking the car or anything.
    but after hearing that i would need a DRC recharge im seriously considering not doing this. recharging the DRC just seems redundant. in the future i do plan on going with coilovers though.
    the other option is getting bilstein sport shocks or the B14 coilover system
    Jan 27 2013
    I got the bilstein PSS9, and been very happy with it, I believe PSS10 does not fit on our cars but not I big difference from 10 as far as I understand. Yeah, 1/12 of the cost of 4% is tough to beat!
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    yea its just one of those things. like even though its 4% its essentially going to be a waste if i upgrade to coilovers anyways. however for now i am getting a bunch of other work done and need to budget out everything. replacing stock DRC struts seemed like a good idea but i def do not like the recharging of the DRC.
    Jan 27 2013
    Yeah I get it, I ran on mine leaking a bit for a year without issues... Audi said it was "sweating" and that was on the re-call ones/upgraded. So if it's not that bad you might ride it out until you do coils. I would do some steel braided lines when you are in there dumping fluid. I got the sexy red ones from ECS and really happy with them, Bd definitely noticed a difference, plus added some high temp fluid... Or 'higher' temp fluid.
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    the more and more i look into this, i feel like waiting it out and doing coilovers properly. for now i might just do the control arms as the bushings are absolutely screwed, the struts seem to be okay though, not sure about the right one though.
    Left strut:
    Right strut: the substance in the middle is what concerns me
    Jan 27 2013
    If you want to save some cash, just press in new bushings probably a 100-$200 job, including parts, while keeping stock arms unless you want to go more adjustable on the camber rather than the typical adjustment through the subframe... I forgot but I think stock is like -1 something.
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    i actually ended up getting the whole control arm kit for the front inlcuding tie rod ends (which i need) for like $300. for now those should suffice
    when i finally do get coilovers, the most i will lower it is like 1inch. so i think id be okay with non adjustable arms
    Jan 27 2013
    Yes you will, I am 1-2" down and no probs. Good luck, I am out, back to an amazing show of the "good wife" :)
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Thanks for the input!
    Veteran Member Three Rings 0260's Avatar
    Nov 13 2012
    Pacific NW, USA
    Quote Originally Posted by Reggie View Post
    +1
    2008 Audi RS4 / Suzuka Gray exterior / Silver Interior / Titanium & Premium Pkg. / Sunroof Delete
    2007 Audi S4 / Dolphin Gray exterior / Ebony Interior / Loaded
    2007 Audi A4 2.0t Quattro / Light Silver exterior / Black Interior / S-Line / Titanium Pkg.
    2005 Porsche GT3 / Artic Silver / Black Full Leather Interior / Porsche TechEquip Roll Bar / 13k mi / SOLD!
    Nov 13 2012
    Pacific NW, USA
    Quote Originally Posted by skhan91 View Post
    another way to look at it ...
    Installing new front oem struts and having a competent dealer recharge your system will give you a fresh factory ride. As Reggie said, many of us like and prefer the DRC ... remember: coilovers have their drawbacks and limitations too.
