Results 1 to 24 of 24
    Established Member Two Rings resiew's Avatar
    Apr 01 2010
    S4 2001.5 6spd
    qc
    Lower boost 30psi
    Hey maybe someone can enlighten me here. I tought i could lower boost with a manual boost controller in parallel with n75 but it doesnt. I had k04 with a good tune runing 25 psi but turbos didnt liked it.. So now i have rs6 k24 with same tune hitting 30+ psi. I know need tune but im not ready and its running good just to much boost. So i try with mbc in parallel didnt lowered it.. I removed ball and spring from mbc, still nothing.. So i removed the mbc and connect the hoses direct and still 30+ psi?!? What is it i dont understand?
    Aug 04 2013
    Pennsylvania
    I think if you want your mbc to control boost you need to put it in place of the n75, not in parallel. Try that, and make sure you have it set for low boost and slowly raise it until you're at 25 or wherever you'd like to be
    I'm like a tree. I'm all root
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    You should honestly just keep the n75 unplugged and run wastegate pressure. No point in risking anything dumb happening.
    Apr 01 2010
    S4 2001.5 6spd
    qc
    I tought it would be wastegate pressure the way it is connect now?
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Torn wastegate line?
    Pressure test your wastegates and see if they A. Hold pressure, and B. Open
    Stock engine with some rods tossed in. 11.25@132mph.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Sounds like you have a prob with the charge control lines, or 30psi gates.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Apr 01 2010
    S4 2001.5 6spd
    qc
    Torn wastegates line you think.. What is 30psi gates?
    Nov 16 2010
    WetSide, WA
    Cranked down to 30psi cracking, or maybe boost creeping.
    Nov 02 2014
    Winchester, VA
    Gates that open at 30 psi, or your gates aren't seeing any pressure because the line is torn.
    It's pretty simple really. Time to do some diagnosis.
    Apr 01 2010
    S4 2001.5 6spd
    qc
    Ok i checked and there is a leak in the driver side wastegate line. I can hear and feel it pretty big leak but i could not source it from above. I will have to check under the turbo. The actuators didnt move. Thanks for the help. I hope this can be fixed
    Established Member Two Rings Gotwake424's Avatar
    Dec 14 2014
    DavidhogAJ
    Philippines
    Quote Originally Posted by resiew View Post
    anything can be fixed, somethings are just a bigger pain in the ass
    Apr 01 2010
    S4 2001.5 6spd
    qc
    Yea i mean.. Easily
    Nov 16 2010
    WetSide, WA
    Start looking at motor mount diy's, easy to get to the lines with the mounts out of the way.
    Aug 04 2013
    Pennsylvania
    That sucks. I bought my car with torn wastegate lines... didn't know until I put a boost gauge in lol. But I was able to run a long piece of vacuum hose from the wastegate actuator sort of towards the front of the car then up and back to the tee. lol
    It wasn't pretty but I did it without removing hardly anything and it worked until I had the motor out.
    A few years ago I never thought I'd find myself saying things that end with "...when the motor's out next" lol
    Nov 16 2010
    WetSide, WA
    Thats pretty much how you have to do it with the motor in to stay away from the exhaust manis.
    Its kinda tough to replace the soft lines to the hard lines, but an arsenal of funny pliers helps.
    Dec 03 2009
    PNW, Washington
    I didn't read that all the way before commenting. I'm guessing torn lines, for the gates to be set to open at 30psi would just be completely weird.
    And if you bought these from Sean@SRM he usually checks the gates before shipping them off. Doesn't mean accidents don't happen but he is pretty good about quality control.
    Apr 01 2010
    S4 2001.5 6spd
    qc
    Hey I was able to replace the line going to the wg actuator. Now no leak and wg open around 15 psi. But i test the car with same result. I cant lower boost with mbc. Now im thinking how can i check if there is a leak in the line going from turbo to n75. Is it with a boost leak test?
    Nov 16 2010
    WetSide, WA
    Normal psi test will pressurize those.
    Apr 01 2010
    S4 2001.5 6spd
    qc
    When i try to pressurize that line from the n75 i just couldnt
    Nov 16 2010
    WetSide, WA
    A normal boost leak test
    Apr 01 2010
    S4 2001.5 6spd
    qc
    Ok yes thats what i tought
    Apr 01 2010
    S4 2001.5 6spd
    qc
    Did boost leak test and no more leaks. I couldnt lower boost with the mbc in paralell with n75 for some reason. But when i tried mbc only i can set it to 20 or higher. It does spike 1 or 2 psi with mbc only. Maybe if i used Y fitting for the parralel it would be better than T..?
    Nov 16 2010
    WetSide, WA
    Y vs T wont make a difference.
    What psi are you shooting for?
    Run mbc only and call it a day. The k04 tune is nowhere near being able to control those turbos.
    Apr 01 2010
    S4 2001.5 6spd
    qc
    Yea i guess i will run mbc only. Actually it is a custom tune for hybrid rs6 997. I will try around 25 psi. I dont know why it didnt work in paralell
