    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Red top coils with which plugs?
    I read a good thread (which I thought I had saved somewhere) on the best spark plugs to use with the R8 red top coils. IIRC the NGK bkr7e (or bkr7eix) were preferred over the bkr6e. I also think I read that the bkr7eix-11 were not the way to go. I understand this topic has been beating to a pulp in many threads but I am just having a hell of a time finding the one that went into detail on the correct plug and gap to use for these. My B6 is currently stock. Any pertinent info or links will be much appreciated.
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    for stock get the bkr6e's, the 7e's are for higher boost. The -11 suffix is for the larger gap (0.43mm) and you should use those with the 2.0t/r8 coils.
    2012 A6 3.0T prestige | Midnight Blue Metallic | Nougat | ACC | Stock (gone)
    2003 1.8t 5spd FW(trash) Quattro swap (in progress) | audiUP snub | Depo Ecodes | Mini H1 retro | 4300k | 07k FSI coils | BKR6E | de-badged | BC Type BR | Swift Springs | BBS LM Reps 18x9.5 | 25FTG F+R | Tasteful poke
    Sep 17 2014
    Lakeway
    Quote Originally Posted by ZipMeUpJ View Post
    Awesome, thanks for the reply man!
    Jan 10 2013
    03 A4 Avant 1.8TQ
    South San Francisco, CA
    How much higher boost? I'm only stg 1 so still below 20 (no boost gauge but taking a guess)
    //Auto Union Bay Area : NCAC Member : Motoza Stage 1
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    I ran the Bosch Tri-Electrode at Stg 1 and still run them at BT + 2.0 coil packs with no problems, the NGK are great too this is just another option.
    SOLD the GOINHAM A4 ---> GT2860 Project
