Results 1 to 4 of 4
    Junior Member Two Rings JimmiK531's Avatar
    Jun 19 2013
    Bernardsville, NJ
    Oil Level Sensor Issue 2014 SQ 5
    Since my last oil change (roughly 2k miles ago) I've been having my oil level sensor pop on. First yellow saying add 1 quart but ok to drive, then recently it shows up red saying stop immediately.
    Long story short, it's been to the dealer 5 times in 3 weeks. They can't seem to figure out the issue. Has anybody else experienced this?
    Established Member Three Rings hurricanes28's Avatar
    Sep 29 2015
    Slingshot pearl black
    Massachusetts
    They never reset oil in vcds
    Jul 14 2013
    British Columbia, Canada
    Faulty hood sensor? Definitely has nothing to do with reseting service interval.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    I'm surprised they didn't just swap the sensor. This is a common issue across all brands, and the sensor is cheap and relatively easy to replace. (Or...have they tried this? Can you tell us what's been done on each visit - should be accessible on your service invoices.)
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
