Results 1 to 40 of 62
    Established Member Two Rings Roccorace's Avatar
    Nov 22 2015
    Minnesota
    just found out that my car is TD1
    I just bought an s7 3 weeks ago and took it into the dealer to have it checked out and serviced. It is a 2014 with 26000 miles on it and the service tech just informed me that the car is TD1.
    The question really is, on these cars how much of a panic attack should I be having right now? In addition do I have any recourse on the dealer that sold it to me who specifically cited that the car was not TD1? Finally, and I'm pretty positive I know the answer to this, is there any means of eliminating the TD 1 code by working with Audi USA?
    Sent from my SM-N920V using Tapatalk
    2017 Audi RS7 | Daytona Grey Matte
    - Milltek Non-resonated Exhaust
    - Full LED Color-change Interior Lighting upgrade
    - ECS Flush Spacer Kit
    - OBDEleven modified | Lowered 10mm | VIM | Seatbelt Chime | Heater timers
    Nov 08 2015
    Toronto, ON
    You bought it from an audi dealer... but it wasn't CPO, but they made reference to it being NOT TD1? Am I understanding this properly?
    If it wasn't an audi dealer, how would they know?
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    If it was an Audi dealer and you have paper trails where they mentioned it is not td1, you need a 'conversation' with the dealer. If they dont help, contact AoA Corporate. I do think there was a bulleting out where the code can be removed after AoA authorized ECU flash to stock by the dealer. However, if it was a non-Audi dealer, AoA wont be of much help. If the dealer doesnt help, legal recourse is the only option.
    Sent from my SM-N920P using Tapatalk
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Tough situation. While logically I'd think you should have recourse, given that you have it in writing, it's possible the car may not have not been plugged into Audi's computer/service system while in inventory (or prior to that), and thus the TD1 flag may have just recently appeared when you took it in for service- in which case it will be hard to prove any wrongdoing on their part.
    I've seen an internal document stating that TD1 flag may be removed if the vehicle is returned to stock (I think this is done automatically by the computer).
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    Quote Originally Posted by Roccorace View Post
    Did you happen to buy this car from Chicago? In particular a VW dealer? I was looking for a White S7 with similar mileage and the TD1 was the first thing that made me avoid the car. Sorry to say this but you should have checked the VIN with an Audi Dealer or another dealer. An Audi without a warranty isn't the end of the world but, from my experience, an out of warranty car repairs end up costing you a lot of $$$$$$.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    your car being TD1 can be an easy fix get the dealer to buy a new ecu, it is 2500 and it will clear the td1 and allow you to get all warranty work covered, this will be a new sealed ecu. You can go a step farther and buy your new ecu get a tuner to immo defeat the old ecu and then you can have two ecus so you can swap your tuned ecu out for a stock one at a wimb....
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Veteran Member Four Rings Sd76's Avatar
    Feb 01 2009
    Pa
    So td1 basically states that there are aftermarket modifications in your car that void warranty in your car???? I'm not familiar but will google. Are these significant mods like tweaking engine exhaust or as simple as coilovers and wheels. Thanks.
    Nov 27 2012
    Houston/Texas
    Quote Originally Posted by LINDW4LL View Post
    I am also hearing this as well. I think there has been a shift in the way they are dealing with TD1, at least at some dealers.
    2016 S6 | Prestige | Daytona Grey Metallic (APR Stage 1 ECU/TCU, AWE Exhaust, Eurocode Sways and Links)
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Quote Originally Posted by sciblades View Post
    Immo defeat/off does not work on these ECUs (BOSCH MED 17). The only option is a complete clone. And even then, if the TCU (which is not part of the ECU) or any of the other thousand electrical parts are communicated any info about the 'flashed' ECU and stores it, which it probably does (e.g. a "black box"), then you're still screwed. Far too expensive to possibly still be flagged with TD1, or flagged upon manual review which will happen if you need a significant repair done.
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Mar 20 2009
    Quote Originally Posted by hubris View Post
    I was putting it in simple terms, Audi has done warranty work for me with this system in the past with no issues, I can only speak from what has worked for me in the past.
    Sent from my VS986 using Tapatalk
    Gone
    B8 S4
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by Sd76 View Post
    TD1 is technically any modification to the engine- but automatic flag only occurs when you have a performance tune . However , even with a simple intake, the tech can manually flag TD1 if he wants to be an asshat.
    Senior Member Two Rings DB22's Avatar
    Feb 12 2014
    So Cal
    [QUOTE=LINDW4LL;11243478]Tough situation. While logically I'd think you should have recourse, given that you have it in writing, QUOTE]
    Where did the OP say he has it in writing?
    2014 A6 Prestige. VCDS, Chipwerke.
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by Webtoker View Post
    I do know it was easier probably 10months ago . We could just tell them not to scan the car and it would be ok with them. But now, some dealerships outright deny service if you ask them not to scan. So you really need a very good relationship with rhe service guys to get by. I , for an examply, know the shop foreman at a dealership nearby pretty well. He made sure the car was never scanned. But one tech hooked the car up without the foreman guy knowing. The inevitable happened. Lol. But yes, the internal document does say the flag can be removed after AoA authorizes them to flash the ecu back to stock.
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by DB22 View Post
    Sorry- must have misread.
    Sent from my iPhone 6 using Tapatalk
    -Hayden
    Nov 22 2015
    Minnesota
    I asked about replacing the ecu and the dealer told me it would still be TD1
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    To OP, lets start from the beginning. You bought it from what dealer? Audi? CPO?
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Veteran Member Four Rings HeelBuff's Avatar
    Mar 06 2014
    2014 Audi RS7 APR stage 2, 2017 Audi Q7, 2013 Audi S5
    TN
    I've yet to read about any significant warranty claims on the 4.0TT, with or without a tune. While it's bullshit you got lied to and I hope you get the dealer to own up to this fact, it's probably not the end of the world either way.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    My car isn't TD1, but just to give you a flavor of the asspain involved...when I bought my car back in February, the check engine light came on within days of buying the car. It happened after a fill-up, so I gave it a couple of days and it eventually went away. A few weeks later it came back on. Bought a vagcom, pulled the code, and eventually mentioned it to the dealer at my 25k. Got the usual bullshit "could not duplicate" nonsense. It went away for about 10k miles and in that time I got the car tuned, added exhaust, etc. Now the issue has resurfaced. Gracious Audi shop owner here gave me a pretty solid explanation. Sent the dealer a copy of the code and the analysis and asked them whether they had seen this before, possible causes, and whether they would need me to return to the stock tune. Tech's response via the Service Advisor - "It's probably because of the tune." TD1 is a potentially monumental pain. I'm hopeful APR and GIAC see the light and start offering something similar to what Unitronic has done in allowing folks to flash back/forth on their own, rather than having to pay a frigging "authorized dealer" $100 plus each time this needs to be done, because unless you're Daddy Warbucks, you should seriously think twice about risking that flag if you can avoid it. OP, not sure you have much recourse. Did the tech say what caused the flag to be applied?
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by HeelBuff View Post
    The tunes are very reliable. I did not face any issues on my 3.0T either for the 25k miles that I had the tune on my car. The engine mounts gave out on my car but after a little talk, they replaced those under warranty.
    @Brooklyn - so since you had already mentioned it to the dealer, did they fix the issue for you under warranty? Also, uniconnect is going to he a big hit if it works good. EPL has done the same for B8S4 and people switched to them in hoards. Flash from home is a great tool for people who are not close to the dealers plus when the dealer wants to charge you everytime you go in.
    Feb 12 2014
    So Cal
    What should really chap the OP's loins is if it's flagged TD1 and it doesn't have the extra ponies.
    May 08 2004
    NoVA
    Just got that response from them on Friday brother. My only comms with them since then was to point out that the problem pre-dates the tune. This particular dealer is new to me. Have only used them for the 35k. May take it back to my original dealer and point out that it's come back. Either way though, I suspect I'll be flashing back to stock shortly.
    Quote Originally Posted by agent47 View Post
    Active Member Two Rings squarefoot's Avatar
    Dec 06 2015
    San Diego
    So how do you find out if the used Audi you are buying has been flagged TD1? Can you find out from other than the Audi dealer? It seems to me that the OP could come back at the seller for misrepresentation (assuming it's a dealer and they indicated it was still under warranty)
    2012 Audi A6 3.0T, Premium Plus, 19" Sport Package, Brilliant Black - Stock (for now)
    Previous Audi - 2004 S4
    Mar 20 2009
    just so every one knows when you are flagged with td1 you still get audi care service and such things the only things that become an issue is major warranty work, If your dealer is willing to work with you typically they can call the regional rep and override the td1 issue and still get the work done. If your service advisor is not willing to go to bat with you just get on the phone to Audi of America they will make it right you just bought a very expensive car.
    Gone
    B8 S4
    Established Member Two Rings SunDevil's Avatar
    Aug 18 2015
    Scottsdale, Arizona
    Some thoughts:
    1. If original dealership not Audi .... OP could be SOL. Again ... hindsight would have been to investigate the VIN prior to purchase. But even then ... the car could have been modified after it's visit to a dealership capable of detecting the TD1.
    2. I've modified and applied tunes to many of my cars in the past. I did so knowing FULL WELL that I would be on the hook for any related issues. Pay to play ... as they say. If you tune .... I wouldn't expect that a dealership or AoA would go to bat for you.
    3. If I bought a used car that was flagged TD1. I would be livid. Some are saying just change out the ECU and everything will be fine. I don't agree. Regardless of what anecdotal evidence you may have .... the aftermarket tune or modication "may have" exacted a higher amount of stress on the car.
    4. I have no issues with mods or tunes ... as long as I know what they are and who installed them. OP didn't have this option apparently.
    Current: 2016 A7 Prestige. Ibis White. 20"s
    A8 Black
    996TT Arctic Silver, 6 manual .... my 1st dream car
    997cab Black, 6 manual .....utter disappointment
    997TT Guards Red, body colored grill, 6 manual
    R8 V10 2010 Blue, gated 6 manual
    Sep 22 2013
    Norway
    I just wonder why you don't answer all the questions people ask, in the task of trying to help you ?
    You have plenty of knowledge here, and did ask for help.
    |A7|3.0|TFSI|B&O|NightVision|HeadsUp|Led Headlights|
    Nov 22 2015
    Minnesota
    Quote Originally Posted by Soft View Post
    I am in fact asking for help. Qualifying that I'm not useless in the space shouldn't be offensive...
    I was hoping for someone to say that they were incorrect at the dealer, which having worked at dealers throughout college I know that they often are - especially around matters of modification.
    If my response came off as unappreciative, I apologize - I was just trying to get deeper on the subject. I came to the forum for help on this and respect opinions and facts from enthusiasts.
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    The silence is deafening
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Nov 22 2015
    Minnesota
    Quote Originally Posted by quattro16 View Post
    Not CPO. VW dealer sister store to Audi dealer offended by same group.
    It has an intake and full Milltek exhaust with cat delete. For that reason it also has a tune but dealer specified it was not black listed td1.
    Nov 22 2015
    Minnesota
    Quote Originally Posted by Brooklyn View Post
    Tech couldn't tell. Just came up when he logged the car in.
    Nov 22 2015
    Minnesota
    I went in my Audi dealer, checked the car in and as soon as he put in the vin he saw the TD1. Not a fun moment.
    The original dealer is part of a small chain of dealers including Audi. The sales manager when prompted about the car stated "we had the car run through it Audi dealer and it checks out great, it is not black listed for any reason". Hind sight being 20/20 I should have driven it to the dealer. Carfax doesn't show this as an issue - kind of think they should.
    Oct 25 2007
    Scottsdale AZ
    i guess you should just tune the car? :P
    16 Glacier S6 - Sport, Black Optic, Layered alum, Bloze
    13 Orca Black Q7 - TDI Prestige - S-line - S-line Plus - Air Suspension - B&O - Tech - Towing
    16 Nardo Gray RS7 - GONE
    11 Ibis S4 - Prestige - Titanium - Sport Diff - APR Stage 2+ - 35% Huber Optik - Black BBS CH-R 19x9.5 - KW SC coils - E-codes - RS6 Air Shifter - AK and USS sway-bars and end-links, GONE
    08 GMG S5 - GONE
    01 Casa S4 - GONE
    Veteran Member Four Rings kiku's Avatar
    Jul 11 2013
    2001 Audi S4
    Pittsburgh, PA
    Tune and run 10s
    2008 997.1 GT3
    2015 Allroad
    2014 Ram 3500 Dually (the double wide)
    2014 Phantom Black RS7 w/ APR Stage 1 Tune (sold - farewall fast rs)
    2001 B5 S4 (the track slut)
    2013 Q7 S-Line (sold)
    Sep 22 2013
    2016 mercedes c300, 2016 audi q5 3.0,2016
    owings mills/MD
    Is possible that the OP's car became TDI'ed when it was hooked up to the system to see if it was?
    Just a thought.
    When I buy a used car, I don't believe every single word form the seller (person or dealer). I realize there is some risk in not buying new.
    Like when I wait for the check engine light to go off, then rush over to carmax to trade the car in.
    Apr 15 2012
    AriZona
    Quote Originally Posted by etvois View Post
    My dumb question -- what else could have been done to the car other than a prior tune which would have resulted in the TD1?
    Feb 12 2014
    So Cal
    OP - you haven't stated if the car has a tune or not, you have only stated that it has been flagged TD1.
    When VW took it to Audi before selling it they may not have checked for a TD1, they probably drove it, visually inspected it and recycled it.
    Dec 18 2014
    DMV
    OP said audi dealer ran the vin and told him it was TD1. So i'm guessing car was already TD1 when OP bought it.
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    Mar 11 2014
    Dallas/TX
    Per what I get from the OP- the car had a tune, catless exhaust from the get go at the time of purchase. The VW dealer said it is not flagged. Now the OP went to an Audi dealer who just "ran" his VIN through the system and it showed the flag.
    To the OP @Roccorace- they just ran your VIN and had not connected your car to their systems, right?
    Mar 30 2015
    Denver
    It seems to me, though maybe I'm oversimplifying, that there are two possible courses here:
    1) If the selling dealer represented the car 'As Is/No Warranty', then you're kind of SOL. Though, as others have stated, unless they can prove your modifications caused the issue, the warranty must still be honored by Audi.
    2) If the selling dealer represented the car as being under the manufacturers warranty, and not As Is, then you go straight back to the dealer with the law on your side letting them know they misrepresented the vehicle. The laws in pretty much every state regarding warranty and used cars are designed to protect the consumer. Either get your money back or come to some other satisfactory resolution.
    2013 S6 - Estoril Blue - Lunar Silver
    Aug 29 2013
    Mt Pleasant, SC
    Carfax is pretty much useless.
    I had a new Lexus stolen, involved in a high-speed police pursuit and then crashed into a parking garage. Suspect escaped police on foot. Car impounded. Wrecked pretty good, too.
    Got the car repaired by a good body shop. 7 years later, sold the car privately. Ran my own Carfax report just for kicks.... nothing on it. Totally clean report. No mention of the theft or repairs.
    2013 Audi S6 Ibis White, Black interior, LED headlights, 20" alloy wheels, Carbon Atlas inlays, Audi side assist
    Mods Bel STiR Plus, Blinder HP-905, BlackVue dash cams (front and rear), Black Optics grill, Black window trim, XPel Ultimate film, Modesta BC-03 glass coating
    May 10 2008
    Scranton PA
    > I'm hopeful APR and GIAC see the light and start offering something similar to what Unitronic has done in allowing folks to flash back/forth on their own, rather than having to pay a frigging "authorized dealer" $100 plus each time this needs to be done, because unless you're Daddy Warbucks, you should seriously think twice about risking that flag if you can avoid it. OP, not sure you have much recourse. Did the tech say what caused the flag to be applied?[/QUOTE]
    You are so right with this one. Not being able to flash these things is pretty pathetic. My closest APR dealer is a 2 hour drive and it is a royal PIA!
    My best decisions have come after realizing she won't divorce me over that.
    2015 S3
    2013 S6
    2004 996GT3
    1994 RS America
    2001 R1
    1985 FJ1100
    And a whole pile of other stupid stuff.
