Results 1 to 6 of 6
    Active Member Two Rings IM OUTTI's Avatar
    Apr 15 2011
    brooklyn New York
    Unstable RPM?!??
    06' 4.2..... I noticed my car usually idles at 800 rpm. But every now and then (while car is in drive) the rpm drops to about 700 and u can feel the engine shake. I also notice wen using the HVAC the rpm (while in drive) idles at 850 and the problem disappears. Very strange but jus wondering have anyone had this issue and wat was the outcome? Thanks in advance guys.
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    I have had a few random times the car doesn't idle good (feels shakes), it could be a stuck engine mount as they are active and stiffen up at certain times vs others.
    My 06 4.2 idles at 600 rpm in drive and at 700 rpm in park and while in drive with the HVAC on.
    Apr 15 2011
    brooklyn New York
    I've seen some engine mounts going for $330 each. Any recommendations on a good set.
    Established Member Two Rings kocyk123's Avatar
    Nov 02 2015
    2001 Audi A8L
    Harwood Heights IL
    Search the part number in google and you will find them for around $260 OEM. I also have one that needs to get replaced
    Current rides:
    1. 2013 Hyundai Azera Tech 50k miles
    2. 2001 A8L 4.2 Quattro 211k miles
    Sold:
    1. 2007 A6 4.2 FSI Quattro 77k miles
    2. 2007 Acura TL Nav at 86k miles
    3. 1996 A6 Quattro at 155k miles
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    Carbon build up?
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Jul 02 2013
    406, MT
    The 2006 4.2 isn't FSI, and isn't subject to carbon buildup... Well not bad carbon buildup, you can still get a little bit.
