What causes the battery light to come on besides the battery itself? My battery is a red top optima that is only a few months old and when I scan with my ross-tech scanner I am not getting any codes that could possibly pertain to the battery or charging. Any ideas would be appreciated since I will be taking a trip for Christmas soon and i don't want to have any problems.
This is my most recent scan:
Thursday,03,December,2015,19:43:28:01549
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
www.Ross-Tech.com
VIN: WAUGL78E46A181912 License Plate: DECEMBER 3
Mileage: 194250km-120701mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUGL78E46A181912 Mileage: 194250km-120701miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E2 910 560 A HW: 8E2 907 560
Component: 4.2L V8/5V G 0030
Revision: --H01--- Serial number:
Coding: 0007771
Shop #: WSC 22130 444 84210
VCID: 2541A124ECE70B1638-8070
2 Faults Found:
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 192552 km
Time Indication: 0
Freeze Frame:
RPM: 1709 /min
Load: 61.9 %
Speed: 14.0 km/h
Temperature: 45.0°C
Temperature: 39.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 192552 km
Time Indication: 0
Freeze Frame:
RPM: 1709 /min
Load: 61.9 %
Speed: 14.0 km/h
Temperature: 45.0°C
Temperature: 39.0°C
Voltage: 13.462 V
Readiness: 0000 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 F HW: 09L 927 156 B
Component: AG6 09L 4,2 MPI USA 0030
Revision: --H01--- Serial number: 4121161
Coding: 0000002
Shop #: WSC 06335 000 00000
VCID: 2A5B521885F9246E15-807E
No fault code found.
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
Component: ESP8 quattro H06 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004902
VCID: 2959AD1480FF2F761C-807C
1 Fault Found:
00526 - Brake Light Switch (F)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 6
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0880
Hex Value: 0x4006
Hex Value: 0x0004
Hex Value: 0xB0AA
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6DD199042797F356B0-5122
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0504
Coding: 01023
Shop #: WSC 65536
VCID: 3B75675C2963ADE67E-4B00
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW:
Component: SDAR XM
Revision: Serial number: AUZ4Z7E9040485
Shop #: WSC 00000 000 00000
VCID: 2B55571C89033D66EE-517C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N001A033
Coding: 0032607
Shop #: WSC 98765 666 30530
VCID: 3C7764407F6DAADE77-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 35Z1X
Subsystem 3 - Serial number: 0001.01.000000200000000000˙†63
Subsystem 4 - Serial number: 000000˙†6332DRB40285888E-˙†63
Subsystem 5 - Serial number: 5888E-˙†6342DRB402920C1FP˙†63
Subsystem 6 - Serial number: 20C1FP˙†6352ARB400AE9C8D5˙†63
Subsystem 7 - Serial number: E9C8D5˙†6362ARB400A6679F-˙†63
Subsystem 8 - Serial number: 6679F-˙†63729RB400D7564DV˙†63
Subsystem 9 - Serial number: 7564DV˙†63829RB400D756BC ˙
Subsystem 10 - Serial number: 756BC ˙
3 Faults Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 18
Reset counter: 39
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04141
Shop #: WSC 06335
VCID: 418915B44B8FC73624-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 982 C HW: 8E0 920 982 C
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0023101
Shop #: WSC 22130 444 84966
VCID: 2E535E08BA11484EC9-5122
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023101
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: 71E985743BAF17B694-4B00
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
Component: RNS-E US3 H71 0110
Revision: 02S Serial number: AUZBZ7E2450219
Coding: 0109637
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 134
Time Indication: 0
Date: 2015.09.17
Time: 22:04:19
Freeze Frame:
Mileage: 655350 km
Count: 312
Clock: 19:34
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3332
Coding: 11836
Shop #: WSC 06335
VCID: 0407DCA0141D121E4F-4B00
Subsystem 1 - Part No: 8E1959801G
Component: Tőrsteuer.FS BRM 0506
Subsystem 2 - Part No: 8E1959802G
Component: Tőrsteuer.BF BRM 0506
Subsystem 3 - Part No: 8E0959801E
Component: Tőrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tőrsteuer.HR BRM 0606
6 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 285FA8109BF5167E03-807C
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH03 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0109637
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 134
Time Indication: 0
Date: 2015.09.17
Time: 22:04:19
Freeze Frame:
Mileage: 655350 km
Count: 312
Clock: 19:34
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 G HW: 8P0 862 335 G
Component: FSE_255x BT H21 0190
Revision: 00000001 Serial number: 00000000365378
Coding: 0011877
VCID: 3A7B6258765994EE65-5140
End-------------------------(Elapsed Time: 08:04)--------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 0F: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 25: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 46: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 77: DTCs cleared
