Results 1 to 3 of 3
    Oct 12 2015
    Seattle,wa
    check engine code: P1130, P0174, P1138 FIXED!!
    Ok so i have a 2005.5 S4 and i have the usual intake, catless DP to full exhaust, and i just recently installed the JHM Plenum spacers since i was replacing the oil filter housing o-rings. For awhile i was always clearing the light for a bad sensor that i probably banged around a little too hard during install. So i replaced both sensors but still consistently showed a code for bank 2 too lean. I kept reading about vacuum leaks and since the hoses are so small and brittle i figured one is leaking. I re checked everything and re tightened the manifold and still ran into the same code. I also heard it could be the MAF but it never threw a code for the MAF and i didn't want to throw money blindly at it. BUT i work in a dealership so i picked up a aftermarket BOSCH one for relatively cheap. I replaced the MAF and BAM its fixed! no more light or anything. I just wanted to post up my issue and what i did to fix in hopes it can help someone else!
    Brilliant Red 2005.5 S4 JHM Tune JHM Plenum Spacers Catless DP-SOLD-
    2000 Laser Red S4- K24's, SRM Sidemounts, Forged rods, JHM transmission rebuild kit
    F-150 2013 Ecoboost- Cold air intake, Superchips tune
    2012 BMW X5 35I- wifes daily
    Nov 12 2015
    Oregon
    awesome good to hear!
    My build log
    May 16 2008
    WA
    Finally you are one the forum!!!
    Welcome to the cool kids table!
    When are you going to shoot some footage of the new exhaust and get around to editing and posting it? The audio track would likely make a few peoples pants tight...
