To start I'd like to thank llBen in the UK for the helpful tips as well as forwarding a diagram of the skid plate from ETKA. I'll post a brief overview below for anyone interested in doing so themselves.
I'll start off by saying that you really do need a lift. I'm sure there are ways around, but when I tried sans one I gave up. Also since you have to turn the wheel to get to the last screw in the wheel liner, a Rhinoramp is of no use.
* There are at least 30 screws of various types: Philips, quarter turn, torx, allen, XZNs etc. (I lost one... I'm sure I'll gain an extra 0.2 mpg)
* The skid plate comes off (eventually) with the black plastic air dams
* There are 5 (on each side) screws on the bottom of the wheel liner that need to be removed. In order to get to the last one (on each side) you need (at least on my 285s) to turn the wheel hard right or left to gain access
* It does require a crush washer. This washer may have embedded itself onto the bottom housing and the threads. You thus need to carefully pry this old washer out and replace it. Please check the update post for part numbers.
* The drain plug is a 6mm Allen which was a pain to get to fit due to the paint - 5.5 wouldn't fit and 7 was too big and it was tight as hell. Make sure you get the socket all the way into the plug before applying any force as it will strip in no time.
In over 40 years of working on cars, I must say I've never seen a more over engineered design to hold a flimsy piece of metal in place. Whilst i had it out I noticed that the pan had an indentation pre-stamped so I thought, how about cutting that out and making an access port to the drain plug. But when I fitted it back temporarily to see whether it aligned, alas it didn't and given where it is there's no real way to do this. However now that I've done it once I'm sure it will take me less than 1.5 to 2 hours the next time.
I've now, at 926 miles changed out the factory 5-30 or whatever they had in there for 10.2 qts of 0-40w Mobil1 with a new filter (same as the VW V8 Touareg I may add - so save some bucks rather than ordering an "Audi" oil filter) and can look forward to 50 below in comfort.
Post if you have any questions. I did take some iPhone pics but they turned out of such poor quality that I'm not even bothering to post other than the ETKA diagram of the skid plate, thanx to llBen again. It doesn't show the liner screws nor the air inlet screws that are bolted onto the frame, but need to be removed, but it's the best I found. There is absolutely no information on AllData.
siberian
PS Some of the marking by llBen referring to Torx are actually XZN or triple square screws
Skid Plate
