Results 1 to 12 of 12
Thread: A4 fuel?
    Sep 25 2015
    Wisconsin
    A4 fuel?
    Wanted to know if I had to use premium fuel for my 2.8 B5 A4.
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    It should say on the gas tank flap, along with tire pressure specs.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Dec 10 2013
    Borden, Ontario, Canada
    Is recommended. You can use 87 but you lose power and efficiency
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Established Member Two Rings clause$'s Avatar
    Jan 26 2015
    Mammoth Lakes, CA
    That's not how gas works.
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    91 is what's required, if you can't get 91 get the closes Octan you can.
    This in a nut shell.
    http://http://m.caranddriver.com/features/regular-or-premium
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    Quote Originally Posted by Bordom View Post
    Also you'll get carbon buildup
    Sep 25 2015
    Wisconsin
    Quote Originally Posted by bmos View Post
    It says 95 for some reason on my gas flap but and I've been putting 93 in it because that what's available at my nearest gas station and a lot of people say, I should be using 91. Have I been doing anything wrong?
    Apr 03 2014
    17 GTI Sport
    Alright so most gas stations in the US and Canada for that matter rate fuel octane using the Anti-Konck Index (AKI) also known as (R+M)/2, that stands for Ron + Mon divided by two. Ron and Mon are two different octane numbers to rate fuel quality. Europe and the rest of the world list octane using the Ron octane number at the pump. As such the larger number displayed on your gas flap is 95 Ron, underneath that it should say in smaller lettering 91(R+M)/2 or some such.
    Basically here in the U.S the highest pump octane number shown is 91 (R+M)/2 although the quality of the gas in the 91 pump can be up to 93(R+M)/2, and there are some stations that offer 93 or 95(R+M)/2. These are the equivalent of the 95+ Ron rating for europe.
    I did have to use wiki to make sure I got the terms correct as I had thought the U.S used Mron (probably because Enron why not) while the rest of the world use Ron.
    Nov 17 2011
    Fredneck Maryland
    Quote Originally Posted by monster232 View Post
    If your running 93 your fine and if 91 is an option that's fine too, like he said ^
    SOLD the GOINHAM A4 ---> GT2860 Project
    Apr 29 2014
    Maine
    The only thing 93 is doing (without an octane sensor or more aggressive tuning) is wasting your money (although sometimes it also can contain better additive packages for whatever that's worth).
    I wouldn't go below 91 although plenty of people do with mixed results.
    Sep 25 2015
    Wisconsin
    I agree with you on that one, unfortunately 93 is what I have access to.
    Apr 29 2014
    Maine
    Better 93 than 87/89 'though.
    I wish they sold 93 around here...
