FS: 2010 Audi A4 2.0T Quattro 6spd oem+Today*01:27 AM***#1
Hello,
The time may have come to part ways with my car..
Here's the specs of the car
2010 A4
2.0T
6 speed manual
Quattro
159xxx km
Gray (ish blue)
Black leather*
Heated seats
Sunroof
Maintenance:
PCV valve replaced Aprox 20k ago
Spark plugs replaced Aprox 10k ago
Oil changed every 10k with synthetic 5w40 Mobil 1
Ignition coils replaced with red top coils Aprox 25k ago
New OEM battery replaced 2k ago
Modifications:
Airlift Performance series suspension
V2 managment*
Professional trunk built by ChopShop
B8.5 flat bottom s4 steering wheel
B8.5 shift boot and knob
Gloss black wrapped interior trim (normally aluminum, easy to peel off)
Vinyl "camo" on exterior (individual peices, so it's not a wrap but again easy to remove)
CAI modified to be shorter, so no moisture can be sucked up
LED interior lights
LED reverse lights
LED license lights
Exhaust is straight piped after cats. I'm have 1 resonator which basically brings it back to stock even thought there were 3.
**exhaust isn't terribly loud. On cold start, yes however regular driving etc it is perfect.**
Wheels/tires:
18x8.5 work equip anhelo (front)
18x9.5 work equip anhelo (rear)
205/40*Yokohama*s-drive (front) driven 1 season, feathering on outside but tons of tread
215/40 Nankang ns1 (rear) Aprox 5mm tread, almost no wear
Wheels are extremely hard to come by, especially in 5x112
All offsets are 46
Will include 30mm spacers with bolts to obtain et16 which is damn near perfect
This has been an extremely reliable car in the year and a half I've owned it. Doesn't burn an obcene amount of oil, like most 2.0T do. No oil leaks, suspension is tight. Will pass safety with no issues at all. No lights on the dash at all. Only reason why I'm selling is because, an opportunity has arose to get into a car I've wanted for a long time. This car did win me 3 awards 😝 woot woot 😎
Unfortunately there's some bad:
Blower motor is a little noisy, but has never failed me.
A right side wheel bearing is starting to get ever so slightly noisy.
The infamous airlift bushings have blown up, causing a knocking from the front left. I have upgraded bushings, just have to put them in.
Also about a week ago, I was rear ended. Car is currently getting repaired under insurance. Not a huge repair. Trunk, bumper, rebar.*
Finally, the drivers door lock actuator has failed and you need to lock and unlock that door manually. The other doors unlock and lock fine with the remote, just not the one that counts.
Trying to be as open and honest as I can with this sale. Lots of money put into her, but we all know, you always lose.
Looking to get 18500 Obo. I have closer to 25k into her, total. Flexible but not willing to give her away.
Located in Oakville,
Will post pictures within a couple days however text me at 905 510 5258 for any answers to questions you may have, and tons of picturs.
Also, no I'm not parting anything out and have no extra anythings
Thanks for reading!
