Results 1 to 10 of 10
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    the 15 year old 208k mile oem spider hose is done away with
    replaced with 034's silicone hose which is a lot more robust than the stupid looks-at-it-and-it-breaks oem plastic assembly
    did discover that with the 034 hose installed, the sai pump wont fit
    not a big deal, will just pick up the block off kit and be done with the sai altogether
    if anyone wants/needs a sai setup, mine will be available soon
    did manage to remove the old spider in most its entirety
    and i had only 3 extra pieces not counting the extra hose clamps
    a little tip for those doing this in the future.
    the connection to the back of the recesses of the engine is a real PITA.
    what i did was take the valve cover connector, wrap it with electrical tape to make it thick enough the clamp well to, and use that for the connection instead of fighting it until the sun sets.
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Senior Member Two Rings X-ZZ4's Avatar
    Jun 29 2015
    Oregon
    Stupid question....what is SAI?
    And this is one of the reasons I've been holding off doing mine.....looks like a real PITA for sure.
    2002 Audi A6 2.7T Quattro
    K04's, Solo Motorsports Intake with 85mm MAF, Bosch 550's, Stage 3 Tune, H&R lowering springs, TSW wheels, other misc crap.
    Recently Gone:
    1999 Chev Corvette - Nitrous, 499RWHP
    2004 Pontiac GTO - Nitrous, 528RWHP
    https://www.youtube.com/watch?v=fQ2r5QQ6jaw
    Oct 02 2013
    05 allroad FBP 6mt, 06 VW Passat Komfort, 08 VW Touareg V8 FSI
    pennsylvania
    SAI= secondary air injection.
    I replaced my spider hose a while back as well. With the SAI pump out of the way, the rear connection are far more accessible. At first, I was trying with SAI in place and was damn challenging to say the least. The biggest challenge was the middle, lower connection. Mine did not want to come off at all, so I figure since I was replacing it anyhow, I just snipped/broke the connector and it came off in pieces. OP, looks like you may have had the same prob? LOL!
    Oct 02 2013
    pennsylvania
    What was the state of the old spider hose? Was it clogged at all?
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    They usually develop cracks or get clogged with that brownish crud. Still have my old connection.. Saving some cash for the 034 silicon.
    Apr 29 2009
    Quadzilla
    Longmont, CO
    Quote Originally Posted by n8henn View Post
    i did; had the same reasoning, its going so screw it with keeping the brittle connector
    surprisingly no, at least the parts i looked at
    some sludge yes, but still 80-85% clear
    Rockin' the Rockies
    Oct 02 2013
    pennsylvania
    Nice!
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    Who coded out the CEL after removing the SAI pump?
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
    Apr 29 2009
    Quadzilla
    Longmont, CO
    Quote Originally Posted by VJ's A6 View Post
    not been done yet, not sure if im gonna do it unless there's someone local to me
    Rockin' the Rockies
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    It's really easy after you do it a few times. Takes me like no time at all anymore. I did make my own though and that adds some durability and flexibility as well.
