Here is the plethora of codes....I know...It awful...Please help me.
Headlights are after market and I am not done with them yet. So pay no attention to that monster behind the curtain.
Tuesday,08,December,2015,17:26:40:39865
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WAULT68E34A090880 License Plate:
Mileage: 281040km-174630mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAULT68E34A090880 Mileage: 281040km-174630miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 L HW: 8E0 909 059
Component: 3.0L V6/5V G 0020
Coding: 0016751
Shop #: WSC 63351 000 00000
VCID: 3E735F5B6AEC0CCE6F-5140
2 Faults Found:
19497 - Powertrain Databus
P3041 - 004 - Implausible Engine Temp. Message from Inst. Panel
16955 - Brake Switch (F)
P0571 - 008 - Implausible Signal
Readiness: 0000 0101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 1214
Coding: 0001002
VCID: 3C7755537CF01EDE41-5140
1 Fault Found:
17087 - Brake Switch (F)
P0703 - 003 - Electrical Malfunction
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04497
Shop #: WSC 06435
VCID: 2643973BC27CB40E07-5140
1 Fault Found:
00526 - Brake Light Switch (F)
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63351
VCID: 63C5CE2FF1CE012620-5140
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
VCID: 356140770FDACF96BE-4B00
2 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
57-00 - Electric Circuit Failure
01504 - Bulb for License-Plate Light (X)
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 3001
Coding: 0010607
VCID: 377D4A7F45D63D86AC-5140
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02041
Shop #: WSC 63351
VCID: 3E735F5B3AEC0CCE6F-4B1A
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D37
Coding: 03210
Shop #: WSC 11264
VCID: 326B7B6BFEB4D8AE9B-5140
WAULT68E34A090880 AUZ6Z0C0232666
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-00 - Open or Short to Plus
00779 - Outside Air Temp Sensor (G17)
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
VCID: 71E9B4673B32A3B6A2-4B00
No fault code found.
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1411
Coding: 11788
Shop #: WSC 63351
VCID: 72EBBB6B3E3498AE5B-4B00
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0003
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0004
1 Fault Found:
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 0407EDB31480A61E79-4B32
1 Fault Found:
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
End-------------------------(Elapsed Time: 05:31)--------------------------
Thank you all,
JW
