I'm going to purchase a BBK right after the new year. Didn't see any compelling Black Friday or other discounts that make me want to pull the trigger earlier than that. It would also be a good thread for future reference.
A Couple Questions to make this valuable to the forum:
1. What Kit - Brand, Rotor Size, # of brake pistions, part #, weight of parts if you've weighed them
2. What Wheels are you running - Diameter and more importantly the offset to know what wheels have cleared which calipers
I will edit the thread as information is presented.
Stock
Rotor Size - 340mm
Piston - 1
Weight -
Rotor: 23.4 lbs
Caliper (with pads): 18.8 lbs
Combined: 42.2 lbs
TTRS Conversion
Rotor Size - 370mm (what I found online through parts search)
Weight -
Rotor: 27lbs -(what I found online through parts search)
Caliper: ???
Stop Tech Trophy Kit
Part #: 83.894.4700.R1
Rotor Size: 355mm
Pistons: 4
Weight -
Rotor: 17.8 lbs
Caliper (sans pads): 7.0 lbs
Combined: 24.8 lbs
Revo by Alcon
Rotor Size - 355mm
Pistons - 4
Rotor: ~16 lbs
Caliper (sans pads): ~9 lbs
VWR Kit
Part # - R65G7BLA
Rotor Size - 360mm
Pistons - 6
Weight -
Rotor: 20.94 lbs
Caliper (sans pads): 8.49 lbs
Combined: 29.43 lbs
