Heyya Azine,
Don't want to turn this into a trans / diff fluid debate. I just placed an order for 5 quarts of the Fuchs Titan Sintofluid 75w80 after all the praise it has gotten from various members and Scotty @ Advanced.
I plan on running this in my freshly rebuilt 01E and rear diff. From what I've read on the forums the trans itself requires a GL-4 fluid and the rear diff a GL-5.
When pulling up specs for Titan Sintofluid, it strictly lists it as a GL-5 fluid. Since I don't have extensive knowledge with trans fluids, here are my questions:
1) Is running GL-5 in the trans OK for the long term? I know Motul and other brands are GL-4/GL-5 compliant. From my brief searching I've read that GL-5 will prematurely wear away at yellow metals (ie brass synchros etc)
2) Recommended viscosity is 75W90, will running a 75W80 fluid be ok? I know more than likely it wont make a difference, but after spending all this $$ on the trans I want to be sure it lasts as long as possible.
3) What is the recommended service interval after a rebuild for a fluid change?
