Page 1 of 3 123 LastLast
Results 1 to 40 of 110
    Mar 24 2013
    Oakdale, CT
    1.8T oil pump and filter adapter conversion
    Who has done this conversion and what were your results? I'm trying to decide if I should go this route or not. The idea sounds great on paper, but the two people that I know of that have tried it ended up with low oil pressure issues. I'm trying to figure out if these were due to something else or if they were a direct result of the conversion. Whatever info you have, lay it on me.
    -Adam
    Veteran Member Three Rings abzoni's Avatar
    Nov 13 2010
    low oil pressure issues? i thought the issue was supposed to be high oil pressure
    anyways, mine hasn't given me any issues and i don't get the excess vibrations that some people experience. in terms of results...it works? i did the conversion so i don't have to worry about the 2.0t pump failing again, but your goal might be different.
    GT3071R, built motor, complete fueling system upgrade etc etc.
    Nov 15 2011
    Montreal | I sell in USD
    The two people you know that did the conversion and had low oil pressure issues used the IE oil filter adapter and an 06A oil filter housing/filter?
    *****I sell in USD*****
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Axis View Post
    Yes. Mec wiped some bearings as a result and EPY caught his before any real damage was done. IIRC, EPY added a shim to the spring in the 1.8T filter adapter to boost pressure. I'm currently trying to get in touch with him since he's been AWOL from the forum lately.
    -Adam
    Nov 15 2011
    ^^ Wow, I'm 1500km from having mine done and was positive that when using the 06A oil filter housing, everything was safe. I'll subscribe and see what info comes out.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Yes. Mec CRUSHED some bearings as a result and EPY caught his before any real damage was done. IIRC, EPY added a shim to the spring in the 1.8T filter adapter to boost pressure. I'm currently trying to get in touch with him since he's been AWOL from the forum lately.
    I don't wipe. I only crush, like i crush box left and right bruhhh
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Lets also add in that I was a noob that had never even spun a wrench and I built my engine and did an oil pump conversion at the same time and installed a turbo so its pretty likely anything else could have caused my failure
    Mar 24 2013
    Oakdale, CT
    I think I'm going to do the conversion, but I'll be adding an oil pressure gauge to my shopping list.
    -Adam
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Samsonknight has it on his with no issues.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by audihere06 View Post
    I tried it too. Didnt work out for me. Samsonknight has it on his with no issues.
    Setails on the setup you tried?
    -Adam
    Nov 11 2013
    Charlotte NC
    First just the pump, then the filter housing and everything. Still couldn't get the oil pressure right. But Im not sure if it was all the conversion that was the problem. Turns out the guy who rebuilt my internals put the wrong bearings in it after he cut the crank. Long story short after maybe 2 hours of run time it blew up again and was beyond fucked.
    Mar 24 2013
    Oakdale, CT
    Yikes. I'm glad I'm doing my own engine so I don't have to worry about someone screwing up my stuff.
    -Adam
    Nov 11 2013
    Charlotte NC
    But i added ie drop in rods while i was in there. Already have forged pistons because bpg engine. Ask samsonknight about his. He has probably 5k miles on his with the pump.
    Nov 15 2011
    3000 miles on my conversion, no oil pressure issues. Installing 32DD oil pressure sensor relocation along an oil pressure sensor wired to my P3 as soon as I find an heated garage. Will provide cold start pressure, idle pressure, 3k pressure for those interested.
    Nov 11 2013
    Charlotte NC
    I have a full conversion kit for sale if anyone is interested.
    Mar 24 2013
    Oakdale, CT
    I would also be interested to see what it is near redline and immediately after cutting the throttle from high load/rpm.
    -Adam
    Oct 24 2015
    Perth, WA
    Ok, so what is the benefit of the 1.8 conversion? Is the oil pump in the 1.8 better for some reason?
    My respray thread
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Okedokey View Post
    It doesn't have the integrated balance shaft assembly. It therefore is simpler and less prone to failure. It also reduces the rotating mass of the engine by a couple pounds and increases the oil capacity by ~2 quarts. The downside is that some people have run into oil pressure issues (both high and low) due to the differences in the 1.8 and 2.0 oiling systems. Some people have no problems with the conversion while others have wiped bearings because of it.
    -Adam
    Veteran Member Three Rings Flexcj5's Avatar
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    I'm in the very long process of my motor build but finally on the home stretch. Doing the full conversion using IEs parts. Hoping it holds together.
    Silver 05 2.0t B7 REVO stage 2+ w/ ER SMICs, RAI DP & Stasis exhaust.
    Debadged and tinted on Eibach/Koni FSDs rolling on Euromesh 3's (245/35 R19 et33)
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Flexcj5 View Post
    Did you go with the full crank girdle kit?
    -Adam
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    No girdle kit. Just the pump and filter adapter along with the the needed small parts.
    Mar 24 2013
    Oakdale, CT
    When you get it installed in the car, I'd also be interested in how you setup you pcv/catch can.
    -Adam
    Jun 17 2013
    jersey city nj
    I the parts on the bench. Is that the special edition Coors lite oil filter housing everyone is talking about
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by vce1232000 View Post
    That's assembly lube. It keeps the mechanic operating smoothly during assembly.
    -Adam
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Definitely curious to hear what your pressures are.
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
    Established Member Two Rings SamsonKnight's Avatar
    Sep 28 2013
    NC
    I'm surprised how the 1.8t oil pump conversion thread keeps popping up. As far as I know, I've only done the 1.8t kit from usp and it is supposed to be pushing more oil pressure than stock, so therefore no need for oil filter housing adapter. I'm beginning to believe that I need the adapter to control pressure. What setup did mec and epy have?
    2008 Ibis White A4 FrankenF23, Custom Tuned by Brandon @Breakout Motorsports, Wosner pistons, IE Forged Rods, 1.8t oil pump, 034 hfc, MagnaFlow Mufflers, Cupra R Lip, S4 Door Blades.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    So I am assuming you did not pull the pistons and such to install. Can you leave the heads on as well? I am not sure if I need it yet or not but I got a "oil pressure" warning light the other day when I went to leave for work so I parked it and took the girls car. I am going to hook up a manual oil pressure gauge to see if there are issues but I am assuming its not going to be good. I just hope nothing else is screwed up. I stopped right away and pulled back in my driveway so HOPEFULLY its alright.
    EDIT: Never mind the question that was here I am an idiot :P
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    MEC's original was purchased by a Canadian, who will be installing it into his new motor from Slimjoker. And he really really hope someone can provide more info on these shims b4 he drops the motor into his car. I tried getting in touch with EPY about it and even posted a pic in my build thread specifically asking exactly where they went and what size shims or washers to use. Never got a solid answer. (Currently have access to any stainless part our brains can imagine due to career change)
    I'll be running a pressure gauge aswell. On the dash and one under the hood off the turbo which will be mechanical pressure. No way to see mechanical gauge from cockpit though unless I decide to run the oil line into the cockpit of the car... Which if it lets go wud be a mess.
    Nov 15 2011
    Quote Originally Posted by SamsonKnight View Post
    From what my friends doing these conversions local are saying, you absolutely need the oil filter adapter from the 1.8T to be able to have the proper oil pressure.
    To be able to use one you need the IE 06F to 06A oil filter adapter. ~200$
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by canadianA4B7 View Post
    4.5mm shim is what EPY used.
    It goes on either end of this spring to increase the preload.
    -Adam
    Aug 17 2013
    Rossford, Oh
    Random semi-related question.. if I am pulling the motor to drop the oil pan.. will a 1 ton crane do the job SAFELY? Also do our engines sit well on stands or are they too heavy?
    I have never lifted a personal engine out of a car, only motorcycles, but I assume its basically the same difference. A DIY for the complete engine pull would be pretty helpful as well.
    Mar 24 2013
    Oakdale, CT
    Yes and yes. HOWEVER, a 1 ton crane might make it more difficult due to the limited reach and height of the crane itself. I returned my 1 ton crane after assembling it and got the 2 ton because it is taller with a much longer boom.
    -Adam
    Aug 17 2013
    Rossford, Oh
    I plan on pulling the front end off (bumper and all) because I needed to do the timing belt and such anyway. I just hate seeing it sit in the garage when I just got my JHM flash cable and tune... and HPFP upgrade... and coilovers... and rear diff mount....and test pipe.. in the mail. Perfect time for a oil pressure light right? Any suggestions on pulling it?
    Mar 24 2013
    Oakdale, CT
    Haven't pulled mine yet. Maybe this weekend or next, depending on weather.
    -Adam
    Aug 17 2013
    Rossford, Oh
    That's where I'm at as well. Garage is large but far from heated lol.
    Mar 24 2013
    Oakdale, CT
    I have a heater but need the door open to have room to move the crane around. I can have the door shut for everything but the actual removal and reinstall.
    -Adam
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    Our engines are light compared to most out there. They sit just fine on an engine stand and a one ton hoist will do it but the two ton is usually more stable and has better reach.
    Nov 11 2013
    Charlotte NC
    I bought a cheapo engine stand from harbor freight and it was just fine.
    Mar 24 2013
    Oakdale, CT
    Same here, I got the smallest one and had no issues what-so-ever. Our engine is light enough that it can easily be lifted by two people, even when fully assembled. After you remove a few parts, you can manage by yourself.
    -Adam
    Nov 11 2013
    Charlotte NC
    Someone should weigh one while it's out for shits and giggles.
