Well after reading on this mild BBK option, I bought myself a set (345mm version) and I'm currently getting everything together to make it work.
Drewgold bought the 320mm version and is also getting everything he needs to make it work and will possibly chime in.
The reference thread in the B6 section with lots of good info
The reason I call it a mild BBK option is because :
1 - Its a 4 pistons caliper vs the usuall 6 piston caliper BBK
2 - Its a 2 piece caliper vs a 1 piece caliper
What makes it an attractive option :
1 - Its a 4 piston caliper vs our single piston caliper
2 - Its one piece caliper/carrier design (Caliper is two assembled pieces)
3 - Its freaking aluminium and weights 9 pounds
4 - Pad change is a breeze
5 - Possibility to run them with your actuall rotors (320mm version)
6 - Possibility to run them with S4 2 piece floating rotors which offer better cooling for those who track and dont want to transfer heat to the hub/bearings (345mm version)
7 - No need for machined rotors and/or special bolts. These bolt right to our hub and you can use either B7 A4 or B7 S4 rotors of your choice.
Now, these can be found used from a salvage yard, so if you're unsure if the ones you're looking at are from a 2.0T or a 3.0T/3.0Tdi look for the "handle" in the built in carrier. No handle = 320mm and if it has one = 345mm. Be carefull I've been told these calipers are also offered on many other cars and the carrier holes wont match.
2013+ Audi Q5 320mm version from the 2.0T
Part number :
8R0 615 107 F
8R0 615 108 F
2013 + Audi Q5 345mm version from the 3.0T or 3.0Tdi
Part number :
8R0 615 107 G (Pre-revison = E)
8R0 615 108 G
***Handle on the built in carrier***
***Borrowed image from the B6 thread***
ECS sells the single sensor in their kits so I assume this would be ideal. Single sensor is part number 8R0 615 121 and it looks like this :
These are the different brake wear sensors that could work :
EDIT 01/19/2017: Used part number 8R0 615 121 A (#12 in image below) on the 2.0T Q5 setup I did on my B6 and its a perfect match.
Nice option to tie up the brake pad wear sensor clip to the brake hose :
Click here
1 - 002595ECS04A Which is a brake pad wear sensor bypass
2 - 7L5 907 637A Which is the sensor for the Audi Q7 or VW Touareg (Not a good option since you'll need to cut your oem pad connector and solder them on the sensors)
3 - 8R0 615 121 [22-07-13 >> 27-04-15] 8R0 615 121 A [27-04-15 >>] Which is the part number for the 2013 + Q5
I ordered the dual sensor version from the Q7/VW Touareg and will see if it works, if it doesnt I'll modify it to single sensor and I'll edit accordingly. <---Had to cut the connectors and soldered the ones from my oem pads on them. Go with 8R0 615 121 A (#12 in image below).
345mm Q5 Caliper weight:
For the Americans, that's 8.99 pounds
So far from what I noticed you cant run S4 dust shield with the 345mm version. Will probably cut part of it that comes in contact with the built in carrier.
You can use MKIII 2.0L SS brakes lines : A model available on ECS
I'll edit later with more details
Built kits from ECS :
Front Big Brake Kit - Stage 3 - 2-Piece Cross Drilled & Slotted Rotors (345x30)
Front Big Brake Kit - Stage 3 - Cross Drilled & Slotted Rotors (345x30)
