Results 1 to 14 of 14
    Dec 07 2015
    Wisconsin
    Cat Delete Result
    New guy here! I have a 2003 A4 1.8T Quattro and have done a res delete and replaced the stock mufflers with dual magnaflows. I didn't get the sound I was hoping for. I don't want straight pipes (too loud) or a fart can (shitty sound). Hoping these magnaflows would give it a lower/louder tone.
    Anyways I bought a 3" Cat Delete. What kind of gains will I see if any? Also will it make my exhaust louder since I already have free flowing mufflers?
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    It will make the exhaust a little bit louder. The gains can vary depending on other mods. I'd say ~15hp gain on stock turbo.
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    15hp gain by deleting the cat is doubtful
    Senior Member Three Rings Blockis's Avatar
    Jul 25 2012
    Boston, MA
    Quote Originally Posted by KHARDa4 View Post
    Yeah, maybe right out of the factory...
    Aug 26 2005
    Cat delete will most likely cause annoying drone also.
    Vorsprung durch Technik
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    I added a high flow cat and it made the turbo spool much faster. No cat I'm sure would be even more then mine.
    Please Drive Right
    Senior Member Three Rings UCFQuattroguy's Avatar
    Jul 05 2005
    '01 Audi A4 TMQ
    Orlando,FL
    Cat delete on my B5 1.8T added a nice little bump in torque. Thing about it: You're removing a restriction from the place containing the most heat/energy and expansion. Boost/torque onset is much more aggressive. Granted, it's been about 8yrs or so since I've run the OE cat, but I seem to remember usable torque starting at about 3,000rpm with torque peak around 3,600rpm with a sharp drop-off after 4,500rpm. Now I start getting good usable torque about 2,700-2,800rpm and the acceleration plot being pretty flat from 3,000-4,500 and the hard drop-off doesn't really start until after 5,000rpm. More area under the curve = better.
    I can't speak to the sound/drone, as our exhausts are completely different. Deeper? Yes.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Must be nice to live in an area where emissions testing is not required. A test pipe (deleting the catalytic converter) can help to produce a deeper and slightly louder tone. You may also experience possible droning carried into the cabin, but I would imagine you would have already experienced that when you eliminated the center resonator. Another thing you'll have to deal with are the codes thrown from the O2 sensors. If you have a tune, see if they can code out the cat so you don't get codes (which can cause your engine to behave differently).
    USP CLUB MEMBER #34
    Veteran Member Three Rings USAF Long's Avatar
    Nov 05 2010
    Salt Lake City, UT
    Mine doesn't drone and I have test pipe, dual bullet mufflers in middle, no rear mufflers, 4" tips. I get some interior resonance at cold start, but its my sunroof switch plate I need to put some rubber or something behind it and tighten it. Other than that, its louder than stock in car but not unbearable. Its loud outside though. Cold start pisses the neighbors off.
    - Scott Long -
    2002 Audi A4 1.8t Quattro - 5-sp | 3M Wrapped | Test pipe | Custom Exhaust | Tint | 19" Staggered Wheels |
    Aug 15 2015
    2009 GSX-R 1000 / 99 a4 1.8t quattro (for sale)
    Michigan
    Quote Originally Posted by CyberPMG View Post
    Im running a test pipe and have the P0420 code (cat function below threshold) and haven't noticed any difference in performance other than what the test pipe itself gave me.
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Mine drones like crazy and I love it haha....
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    You'll get an incorrect flow code that will have to be coded out form a tuner. You'll also notice a stronger gas odor when outside of the cabin but the performance is worth it! Faster spool up!
    Edit-Me and my brother have tried the 90 degree 02 spacers on the B6 & B5 with no good results. Still get the pesky CEL after a few hundred miles.
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Dec 07 2015
    Wisconsin
    I'm still trying to get the gf's sister's boyfriend who's dad owns a shop to install it for me. I have all the tools and the mechanical ability but no car lift and I know it will be a bitch on jack stands/ramps alone. MY flex pipe must of recently got a hole in it because it's very loud now. Sounds like straight pipes. Am thinking I wanna install this test pipe and fix the flex pipe, then straight pipe it. I cant find any place near Duluth to install the Cat Delete (obviously) wish I had a lift so it wasn't s bad.
    Dec 07 2015
    Wisconsin
    Unless you think the test pipe combo with a new flex pipe and the magnaflows will sound as loud as the car does right now with a hole in the flex pipe.
