Originally Posted by
96PearlyWhite
Did you use the cup trick? I have to do mine this weekend while I am replacing the clutch. The hardware is reusable right?
I didn't use the cup trick, the part I bought had a tool preinstalled. the cup trick looks like it would work damn well. the tips they both gave worked really well for me. lightly oiled the crank it slides onto helped a TON. I went very slowly while pushing it on and made sure it was going on completely straight. people made it sound like the bubonic plague and to stay away from doing it. I didn't think it was that bad. a little intimidating because of the reprecautions of doing it wrong, but just take your time.
the metal flange around the felt/rubber seal come as a pair. there's also a paper gasket behind it. clean up the block mating surface really well. I used a razor blade to scrape off at first and then lightly rubbed fine steel wool on the surface. it cleaned up well.
