2005.5 Audi A4 Avant 2.0t 6mt in Ocean blue pearl -116k
2005.5 B7 A4 2.0T Avant 6 speed manual
~116k miles
Ocean blue pearl over tan interior
Bixenons+AFS
Front and rear heated seats
Color DIS
Cargo cover
Mods:
JHM stage 1
JHM stage 1 clutch with lightweight flywheel
Dru Yoder airbox mod
Koni Coilovers
034 Rear sway bar
JHM shifter bushings
JHM shift linkage
All season mats w/ red ?S? badge
A6 s-line wheels w/ Continental extremecontact dw tires
35% tint all around
Maintenance since I have acquired the car:
Front suspension overhaul(new control arm bushings, upper and lower, inner and outer tie rod ends, sway bar end links)
Timing belt (waterpump, coolant, rollers etc)
In tank fuel pump + fuel filter
Power steering rack+fluid
Timing chain+tensioner+cam adjuster + associated gaskets/seals
Cam follower has been changed every other oil change
Oil changed every 5-7500 miles
Low mileage turbo was swapped in, old one failed
Spark plugs
Sunroof lubed+rattle fixed
Diverter valve(Rev D.)
034 Motor mounts
New OEM battery
Dealership replaced cam+ HPFP + associated seals under warranty (cam follower failure)
Known issues/upcoming maintenance:
Brakes
Camber wear on tires from being low
Interior trim is half brushed, I wasn?t satisfied with the finish and never got around to wrapping it
Steering wheel+shift knob could use replacing/rewrapping due to sun damage
Dents/door dings and scratches
Hatch is rusting around the 3rd brake light
Rear ash tray cover is broken(will be included anyway)
Broken glove box hinge
I purchased this car with 87k on the clock from a dealer in New Jersey. The car has been fantastic since. All serious maintenance was performed by a certified Audi technician. I have a binder of records detailing maintenance during my period of ownership. The car is 1 of 34 in this color/engine/transmission and only one of 10 with this interior color. The rear heated seats, color DIS, and bixenons from the factory suggest that this car is basically loaded, minus factory navigation. Audi has stopped importing avants with manuals starting with the B8 generation of the A4. This is likely to be the last generation for a manual avant to roll off the Ingolstadt assembly line. My main reason for selling is that I now wish to get involved in some sort of organized motorsport. The A4 serves as a great cruiser and daily driver, perfectly happy on the highway or in traffic. The 2.0T in combination with the JHM flash software however does provide an engaging driving experience.
Pic posted is of car with an old wheel set up. Please PM for more pics or pic requests.
11k obo. Trades: hawkeye wrx wagons or 06-08 forester XT?s, manual only.
Located in New Haven County, CT
List Date: 12/7/2015
For more info, click here to view the original listing: 2005.5 Audi A4 Avant 2.0t 6mt in Ocean blue pearl -116k
This item is no longer available.
