Results 1 to 11 of 11
Thread: About spacers?
    Established Member Two Rings Axxenice's Avatar
    Dec 29 2014
    Sweden
    About spacers?
    Hello!
    My plans for this winter were to use my secondary car(Nissan Terrano 1991) instead of the RS4 but as it turns out, an old SUV without any safety features and bad tyres is terrifying in icy conditions.
    So i was planning on using the RS as a daily driver instead, I live in northern Sweden so the conditions vary.
    I have a set of 18" winter tires with new Gislaved Nordfrost tyres that i used with my past A4, but i noticed that they hit the front calipers on the RS so was planning on buying spacers so i can use them.
    So my question is: Which spacers should i use?, i don't want to break the bank and i thought that i could maybe use them on the OEM RS summer tires when summer hits again.
    A big + would be if some Swede knows where to buy them in Sweden or if there are companies with international shipping.
    Skickat från min LG-H815 via Tapatalk
    Oct 02 2006
    Wadsworth,OH
    You should be fine with a small spacer. If it's purely for brake caliper clearance you shouldn't need more than 5mm. Could even get away with 3mm. The smaller spacers will be less as well.
    Take a look at our full line that we have available for your vehicle.
    Click HERE
    We ship internationally and also have international distributors who can source these items for you. Feel free to PM me and I can get you in contact with a distributor.
    Jason
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    If you go with just 3mm spacers you can probably also save on the need to buy extended lugs. BTW, you state the tires but don't say what wheels you are having the issue with caliper clearance.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by MacFady View Post
    Ehhh it's really not recommended. The rule of thumb is you should at the very minimum have 6 threads in the hub. Anything less could be a concern for safety.
    If you can fit the wheel on with the spacer and still get at least 6 threads in I don't see an issue but if it doesn't work out better to be safe than sorry and go for some longer bolts.
    Jason
    Dec 29 2014
    Sweden
    Alright!, I use these:
    Some cheap brand and they are at my parents house so can't say ET and other specs :)
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    just be careful with the length of the lug bolts. I've heard horror stories of people using too long of a bolt that they found lying around, for the B8's. Not sure with the B7's, but I would get a bolt exactly long enough for the added width of the spacers.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    Quote Originally Posted by Axxenice View Post
    Hello!
    If you need help to ship something from here, and do it so you don't get to deal with the import "tax", send me a pm and I can help you. Also I usually have friends/family visit here and there and a buddy from Stockholm coming in January and surely he can bring some back. And of course I got to help out a fellow swede! I would recommend the 10 front/back for stock summer, and 10/8 unless you went a wide brand like the DWS where I had to step down the spacers with 275's to an 8/nada front.
    Senior Member Three Rings prfktgntlmn's Avatar
    Sep 24 2011
    2017%20gmc%20canyon%20sle%20
    Atlanta
    I'm going from 10mm to 5mm spacers. Can I use the same lug bolts?
    2007 Audi RS4 Phantom Black/Black Premium
    Veteran Member Three Rings noob5's Avatar
    Dec 09 2007
    Quote Originally Posted by prfktgntlmn View Post
    Doubtful.
    Even a few mm's too long and the lug bolts will likely bind up on the hub.
    '13 allroad Monsoon | APR K04/hfc/downpipe/FMIC | H&R | 034
    '07 RS4 Imola | JHM 93/Stg4 clutch/Shifter trio/Intake spacers | KW HAS | 034 t-mount/linkage arms | Stoptech rotors/pads | Milltek DP's | ECS H-Pipe/motor mounts/rear diff mount
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    99.5 A4 2.8Q Volcano Mica
    02 S4 Santorin
    04 allroad 2.7T Alpaka
    10 Q5 Brllnt Blk
    Oct 02 2006
    Wadsworth,OH
    Its not recommended. You should always use proper size bolts with spacers.
    Jason
    Sep 24 2011
    Atlanta
    Jason
    Ordered a set from you guys earlier today😊
