Hey guys, recently I have noticed my coolant tank continues to drain at a consonant rate of 2-3 days after I fill it up. It's a 2011 B8 S4 with the upgraded water pump. I had the thermostat replaced with the all metal housing replacement after the plastic one gave out on me. I can not identify a leak of any sorts via looking for frosted/dried coolant in the engine bay. Luckily it's winter and the car can run just fine without overheating however I want to get it fixed asap. I was wondering if anyone has run into this same issue of a draining coolant tank? I'm assuming it's a loose hose somewhere in the system, but I cannot find it. I was planning on taking it in for a check up at my local Audi dealership, but they are going to charge me at least 150 for the check up just to diagnosis. Before I take her in I wanted to check here with everyone and see if they have any advice about were to look or any tips or tricks on isolating the issue.
Any recommendations are greatly appreciated. Thank you in avance.
