Results 1 to 3 of 3
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Fuel System Related Fault Code
    When I bought my car back in February, My check engine light came on while idling in traffic. It went off on its own and came/went a few times after that. Went about 10k miles or so and now it's back, twice in the last 30 days or so.
    Both times after getting my car washed and both instances since installing the Milltek non-res. I'm guessing the Milltek is a coincidence. Possible that the car wash dudes are opening the gas cap while the car is idling while, but I've been going to the same car wash for a while now and this has only recently popped up again. Anyone have any ideas? Problem with the gas cap?
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
    Established Member Two Rings Blairautomotive's Avatar
    Jul 11 2015
    Frisco Texas
    This fault code is not related to the gas cap. While its possible that this may be correlated to the car wash I cannot think of anything that makes much sense. 310B faults most commonly occur due to low side fuel pressure issues with either the in tank pump or pressure sensor. With a fault frequency of 8 this issue will most likely continue until the cause is repaired.
    2016 Audi S3 Viper Green Audi Exclusive, AWE Switchpath Exhaust, HREff15, Stoptech 380mm, Emmanuele Design Springs and Carbon Fiber, Eurocode Sways/links, APR Stage 3+
    2016 Golf R Oryx White DSG
    Master Guild Audi Tech
    Owner of Blair Automotive in Frisco Texas
    www.blairautomotive.com
    North Texas dealer for APR, AWE Tuning, VMR Wheels, JHMotorsports, 034, Eurocode, ECS Tuning.
    May 08 2004
    NoVA
    Appreciate the detailed analysis chief! That's a far better explanation than I received from the dealer. Going to take it to another dealer I've been using recently and mention your comments.
