Results 1 to 12 of 12
    Veteran Member Four Rings jolio1994's Avatar
    Sep 06 2011
    Little Egg Harbor, NJ
    Silvaro STK Build
    Long story short I traded my Stage 2 Cactus for this Single Turbo S4 back in September. On the way home as I was getting of my exit I decided to do one pull and the car threw a rod... spike 31 psi on a 23 psi tune.
    So, month later I took a week off, got the car to West Points Hobby Shop, and pretty much just swapped motors with a low mileage one I was able to pick up.
    I took off the old Valve Covers and Manifold off the old motor and did some nice painting. Not powdercoat, but it will do the job...
    I hate the way he did the engine bay, ultra trashy but whatever... lots of connectors broken, and wires frayed. Rather then making a new harness, I bought a used one and will piece toget her a custom one. Everything in the passenger side will run behind the firewall.
    It's not there yet, but I'm nearing the end of where I want to be with this car. Still cleaning up the bay, and hopefully by the end of this week the harness will be done. 👍👍👍
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    nice, did you build the block when you swapped?
    Sep 06 2011
    Quote Originally Posted by rguil View Post
    No, I was short on time and unprepared... I bought high mileage motor a few days ago. I'll go through the while thing and hopefully be looking at a 6262 sometime in the Fall of next year.
    Sep 07 2012
    Tucson, AZ
    How did the engine spike to 31psi?? Sucks it happened man, but glad to see you're getting her all straightened out. Keep up the good work 😎
    Sep 06 2011
    Thanks man!
    Here's what the bay looked like the day I got it. It's coming along nice
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    awesome! this is were im looking to go with my next s4 keep up the build
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Aug 24 2014
    Newport Beach, CA
    Did they move the secondary firewall back to fit the turbo in? Looks like that battery is non-removable!
    2024 M3 Comp xDrive
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by christianb5s4 View Post
    If you look under your hood, you'll see the battery is half under the rain tray. Secondary firewall is untouched.
    Aug 24 2014
    Newport Beach, CA
    Ah, you're right. For some reason it looks like the secondary firewall was pushed back a bit so was curious.
    2024 M3 Comp xDrive
    Oct 26 2015
    South Dakota
    That is an interesting setup, I like it!
    Sep 06 2011
    Maybe someone can answer a question real quick. Trying to undo the ******y of the previous owners wiring. The colors on the map sensor isn't matching up to the harness... any ideas?
    Jun 14 2007
    2000 S4
    Connecticut
    I read the title as "Silvarado" STK build. Was expecting to see a pickup with a 2.7 T in it.
