Results 1 to 26 of 26
Thread: Freak situation
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Freak situation
    Ok so I am about to leave today start my car and it struggles to start, but starts. Rather than risk it we take my wifes car, get home run the codes and I get one for P0343 camshaft position sensor and one for P150A. If anyone knows about the latter please give me some insight, but the first code however I just figure I would check the engine and found this
    it looks as though the wire was ripped apart, and more so than usual were some leaves there like animals were in there. My car normally sits in the garage but has been out for the past couple of days.
    My question is does the sensor replace the wiring that is ruined? And does anyone know about the P150A code seems rare?
    I am a 2009 Audi Avant with 110xxx
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Looks like a mouse got in there. If you are competant with wiring splice the wires back together with a soldering gun and heat shrink wrap....its not a rare code for Audi's.
    2016 S3
    Instagram- @Thisisastickup
    Active Member Three Rings DoctorB8's Avatar
    May 11 2013
    2011 Audi A4 Premium Plus
    Oak Ridge, NJ
    holy oil batman... get that valve cover taken care of lol. Looks like you have a tenant not paying rent... Little solider should do you good. keep an eye on the oil though
    APR | Eurocode | Stasis | Stoptech | 034 | CTS
    EUROgrade Official Meet Thread
    Follow @_eurograde on instagram
    Jan 14 2010
    Georgia
    PC Principal, no not the code for camshaft sensor the P150A seems to not be much out there, and the car does not drink oil its just dirty. I would like to replace the wire completely anyone know what wire that would be?
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by bluetori View Post
    Replacing that wire would most likely mean tearing your engine harness apart. If you can repair it via solder and shrink wrap then that is the way to go 110% it will function and be protected as if it was new. P150A, i've read about a software update resolving that issue on the late vw 2.0t's.
    2016 S3
    Oct 10 2012
    Zionsville and Saint John IN
    Yeah no need to replace the harness just listen to pc principal
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Jan 14 2010
    Georgia
    Ok and I have my consent form whenever you want it.
    Oct 27 2010
    Norwood, MA.
    Hahah. The latest season of that show has been soo good.
    2016 S3
    Jan 14 2010
    Georgia
    Quote Originally Posted by b6Hate4 View Post
    Yeah it has it's intense
    And to be clear I assume I need to just disconnect the battery like with any wiring.
    Oct 27 2010
    Norwood, MA.
    Yup. If you doubt yourself at all I would suggest having a friend who works wiring/ electronics ect take a look...I soldered my fan control module myself on an older a4 I owned, it looked like a hackjob but it worked for 75k miles untill I got rid of the car.
    2016 S3
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Or, use some nice wire connectors and shrink wrap over them. May need to splice in a piece of wire to make up the gap
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by blbroo View Post
    I was going to suggest this, infact I even had repaired my FCM with crimped wire connectors originally, but my mechanic friend warned of possible corrosion with the wiring being in the elements. However the Fcm harness I repaired sits directly behind the grill (ultra exposed to elements) unlike the OP's situation where its a bit more isolated. Just an observation.
    If you are unable to solder I'm sure connectors may also be a viable option.
    2016 S3
    Oct 26 2012
    St. Louis, MO
    I think if you put shrink tube over them, they'd be protected from any elements. Right?
    Oct 27 2010
    Norwood, MA.
    Hahah yeah. I was really kind of thinking out loud with that post. They should be fine.
    Sent from toilet stall #4
    2016 S3
    Jan 14 2010
    Georgia
    Its fixed light is off my buddy came over who happens to live across from me he had a soldering iron and all is well. Some rodent got in there because there were shreds of it everywhere on my intake mani. Glad it was something easy.
    Whoo whoo PC
    Aug 06 2012
    Parker, CO
    Prevent nice from getting in there ever again ----- PURE PEPPERMINT OIL..... not extract.
    I had a critter problem a few years ago on my Sportwagen TDI. Someone recommended sprinkling about 5 to 6 drops in the eligible bay about every six weeks during winter and is never have the problem again.
    Sure as shit ---- I also sprinkle it the peppermint oil in my garage and haven't had so much as a mouse tied in there for years.
    Aug 06 2012
    Parker, CO
    Mice, not nice ---- damn iPhone keeps changing it on me.
    Aug 06 2012
    Parker, CO
    Engine bay -- not eligible. Phone is pissing me off.
    Aug 06 2012
    Parker, CO
    Turd - not tied ----- effing phone
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Quote Originally Posted by treginginco View Post
    Do you lasso them before they are tied up?
    2011 A4 Avant
    Aug 06 2012
    Parker, CO
    Quote Originally Posted by jfo View Post
    Damn straight--- those little bastards!!! 😜
    Sep 14 2006
    Glad you got this easily fixed!
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Jul 07 2012
    Rocklin, CA
    So weird. I got the EPC/MIL light today and noticed that it took a good 4-5 seconds for my car to start up. I ran the code and it was related to the Crankshaft position sensor. I look at it, and the wiring is destroyed in exactly the same place as yours. I have a hard time believing a mouse got to it since it was parked in the garage, and it's a tight fit with the engine cover.
    Edit: Looks like I was wrong. Found a rat/mouse turd in my engine bay. They must prefer camshaft sensor wires :)
    Aug 06 2012
    Parker, CO
    They will find the best, warmest spot and it would appear... this is it.
    Rodents chewing into wiring is a problem for European vehicles. As it was explained to me, wiring harnesses for European brands are very attractive to critters, because the wrap around the wiring is made with a vegetable based product.
    Jan 14 2010
    Georgia
    Quote Originally Posted by hexc0de View Post
    Holy shit. It's nuts
    Jan 14 2010
    Georgia
    Thanks
